Results 1 to 12 of 15
Plumbing & Plumbers Forum - I have a new Stelrad compact to install. To follow MI's or use Loctite 55 instead?
Like Tree4Likes
Discuss I have a new Stelrad compact to install. To follow MI's or use Loctite 55 instead? at UK Plumbers Forums; As part of the upcoming bathroom refit I'm replacing the exising 30 odd year old rad with a Stelrad compact. The existing one has no fins on the back, is ...
    Aug 2011
    Coulsdon, Croydon
    23
    Default I have a new Stelrad compact to install. To follow MI's or use Loctite 55 instead?
    As part of the upcoming bathroom refit I'm replacing the exising 30 odd year old rad with a Stelrad compact. The existing one has no fins on the back, is avocado green with rusty bits. For the sake of £28 it wasn't worth faffing around cleaning it up and re painting.
    The instructions say to use PTFE on the valve threads but I also picked up some loctite 55 as I need it for some threaded connections in the shower install (Trevi Boost) and wondered if I'd be better off just using that to ensure a seal first time out?
    I've seen a lot of people sing the praises of the Loctite on here and elsewhere and mention how easy it is to guarantee no leaks first time out compared to PTFE which sometimes takes 3 or 4 goes to get it right.
    May 2011
    county durham
    508
    Default Re: I have a new Stelrad compact to install. To follow MI's or use Loctite 55 instead
    ive been using ptfe for rad valves for the whole time ive been doing this job, a while now and i get it right everytime..
    obviously if you dont have a clue what your doing, it will leak.. and anyone who has theirs leak after 3 goes aswell is a mug
    AWheating and jackyp1234 like this.
    3,127
    I've never really had any issues with PTFE to be honest. Never used the loctite stuff, so cant really comment on that.
    Nat
    Nat is offline
    Jan 2011
    brighton area
    380
    I use both and never have any problems with either. I always use PTFe on rad tails though as it leaves a neater finish. If you use ptfe then scratch the thread with hacksaw blade, wind on 12 to 15 turns of ptfe in the direction so that when you wind it into the rad it doesn't come off ( clockwise if you are looking at the threaded end of tail) and you won't have any problems. Hope this makes sense to you! Good luck.
  5. The Following User Says Thank You to Nat For This Useful Post:
    quality's Avatar
    Sep 2009
    South Yorkshire
    3,639
    I don't the 55 stuff I use 577 but I thought 55 was PTFE
    SimonG's Avatar
    16,127
    PTFE and magic paste for me, never have any problems!
    AWheating's Avatar
    WestMidlands
    9,638
    why use an expensive product when a 8pence roll of ptfe tape works perfectly? save the good stuff for when its needed.
    He who dares Wins, unless he dares to try and breath under water.
    Blackcatgas's Avatar
    Oct 2009
    Nottingham
    1,675
    Boss white and hemp if your a man, what are you Darren? a man or a mouse?.
    ecowarm's Avatar
    Mar 2010
    lincolnshire
    3,748
    Stag and hemp................. try and undo in a couple of years, I use 55
    946
    12 wraps of ptfe never fails for me
    AWheating's Avatar
    WestMidlands
    9,638
    dont use your hemp, keep it for smoking!!
    dontknowitall and steveb like this.
  13. #12
    dontknowitall's Avatar
    Apr 2008
    Herefordshire
    6,122
    12-15 wraps of ptfe tape for me. Loctite 55 (and La-Co Slictite) for male irons and stuff like that.
  14. The Following User Says Thank You to dontknowitall For This Useful Post:
  1. Is there a Loctite type glue for plumbing joints
    By Oiseau in forum Plumbing Forum
    Last Post: 08-05-2012, 06:20 PM
  2. loctite 577 help on its use
    By hants tiler in forum Plumbing Forum
    Last Post: 21-04-2012, 09:58 AM
  3. Loctite 577
    By Plamber in forum Plumbing Forum
    Last Post: 16-10-2011, 04:18 PM
  4. loctite 55 or hemp on shower mixer valve
    By ojchurch in forum Plumbing Forum
    Last Post: 26-08-2010, 11:14 PM
  5. PTFE versus Loctite
    By antonm919 in forum Plumbing Forum
    Last Post: 24-04-2010, 10:14 AM
  6. Should wet follow gas
    By macplumb in forum Plumbing Forum
    Last Post: 02-03-2010, 06:20 AM
  7. water meter
    By zed75 in forum Plumbing Forum
    Last Post: 23-04-2008, 11:34 PM
stelrad fitting instructions
http:www.ukplumbersforums.co.ukplumbing-forum23897-i-have-new-stelrad-compact-install.html
