Results 1 to 6 of 6
Plumbing & Plumbers Forum - Combi boiler
Combi boiler
Discuss Combi boiler in the Plumbing Forum at Plumbers Forums; Hi, first post and it may be a daft question about a combi boiler, got a new system installed about a year ago,not a bad system, but the problem is, ...
    lester
    Default Combi boiler
    Hi, first post and it may be a daft question about a combi boiler, got a new system installed about a year ago,not a bad system, but the problem is, keeping the temperature stable, it comes on and reaches the temperature set by the thermo, then the whole system shuts down, and then the temp has to drop quite a bit before kicking back in again and the room gets much cooler before system fires up, so the question is, is this normal?? or is something not right.
    Oct 2008
    671
    Default Re: Combi boiler
    somethings not right.
    but need more info on system etc.
    Jan 2009
    windsor
    39
    Quote Originally Posted by lester View Post
    is the room stat near a rad
    lester
    Boiler is a potterton gold 24 HE, remote salus stat, thermostat is on opposite wall from nearest radiator about 6 feet away.
    lester
    There is an option of 1 or 1/2 a degree tolerance, that is set to 1/2 a degree.
    Also should the water pump shut down when temperature is reached or should it keep circulating the water throughout the system even though the burner is off?
    lester
    Quote Originally Posted by fatoftheland View Post
    The pump will only run on to cool the boiler. I suspect the thermostat.
    Unlike a conventional boiler where the pump continues to circulate the water and the flame kicks in as and when the temp drops.
    My first thought was the thermostat, it just does'nt seem sensitive enough, the thermostat readings seem to drop slower than the actual room temperature.
    cheers for the advice.
  1. combi boiler losing pressure
    By ice cold in forum Central Heating Forum
    Last Post: 06-01-2010, 11:26 AM
  2. combi boiler watere pressure gauge below 1
    By corinnemunoz in forum Plumbing Forum
    Last Post: 09-02-2009, 06:47 PM
  3. Is Pumped water into a Combi Boiler recommended?
    By mtotowamungu in forum Central Heating Forum
    Last Post: 11-12-2008, 07:51 AM
  4. combi boiler DHW CH cross connection?
    By wmbmrg in forum Plumbing Forum
    Last Post: 26-11-2008, 11:08 PM
  5. Britony Combi SE 80 - Boiler problem
    By tedson in forum Central Heating Forum
    Last Post: 26-11-2008, 06:31 PM
