Results 1 to 15 of 17
Plumbing & Plumbers Forum - Leaky Shower
Leaky Shower
Discuss Leaky Shower in the Plumbing Forum at Plumbers Forums; rsz_photo1146.jpg rsz_photo1147.jpg Afternoon, One leaking shower. A Bristan 1901. Installed 6 years ago in a customer's house. It's leaking, as the second picture shows, from between the handle section and ...
    Apr 2009
    2,686
    Default Leaky Shower
    Afternoon,
    One leaking shower. A Bristan 1901. Installed 6 years ago in a customer's house. It's leaking, as the second picture shows, from between the handle section and the very next gold ring section. It's a constant drip.
    My questions are:
    1) Which part(s) would I need to replace? I'm guessing some kind of o-ring or seal.
    2) Can anyone confirm which one of 1901 range it is from this link Bristan Spares - Bristan Shower Spares - Bristan Spare or Part I think it looks like this one Bristan 1901 Easytherm Thermostatic Shower Adjustable Riser - Gold | Bristan | Shower Spares | Shower Doctor
    3) Underneath the diagram listed with a hundred numbers there is a available spares list with only two numbers listed. Looks like there is only one o-ring available, would this be the one I'm after?
    4) If yes to all of the above is it just a case of isolate supplies, remove cap, undo screw, pull off pieces, replace o-ring, re-assemble, test?
  2. *brilliant signature*
  3. #2
    Plumbstar Tom's Avatar
    Jul 2009
    Staffordshire
    2,548
    Default Re: Leaky Shower
    1) Seals kit for the cartridge
    2) It looks quite old so would ring Bristan as the shower doctor one looks different
    4) Isolate, take off handles, pull out cartridge, replace seals, grease and refit
  4. Regards
    Tom
  5. #3
    system3's Avatar
    Feb 2010
    Alloa, Scotland
    7,068
    Had a similar problem a few years back and contacted the manufacturers direct. They were very helpful both with the needed advice, and the required part. Call them with the serial number or model number and explain the problem.
  6. #4
    mjt
    mjt is offline
    Nov 2009
    Lincolnshire
    316
    agree with the above - should be a relatively simple job proividing everything undoes ok!!!!
  7. #5
    Jul 2009
    Staffordshire
    2,548
    Quote Originally Posted by mjt View Post
    hmmm, siad that a number of times before!
    Regards
    Tom
  8. #6
    mjt
    mjt is offline
    Nov 2009
    Lincolnshire
    316
    following by swearing sweating and nashing of teeth!!!!
  9. #7
    Apr 2009
    2,686
    Thanks everyone, have emailed Britsan with photo.
    And yes, I've tried to give up on ever thinking a job will be quick and simple but I do fall back into old habbits. Finished a quoted 3 hour job in an hour recently and found myself thinking "Blimey, that went well." Just when I was wondering how to fill up another half hour tidying things up I noticed a weep. Took nearly 4 hours in the end.
  10. #8
    mjt
    mjt is offline
    Nov 2009
    Lincolnshire
    316
    Quote Originally Posted by WaterTight View Post
    oh mate nightmare
  11. #9
    mjt
    mjt is offline
    Nov 2009
    Lincolnshire
    316
    expect an email back in about a week lol
  12. #10
    Apr 2009
    2,686
    Update: Got seals kit through after emailing them a picture. As mentioned before not done one of these before. The seal kit comes with 2 large black rings, two smaller ones and a white plastic one. Do I need to replace all of these when I dismantle on job or is some of it spare / unnecessary?
  13. #11
    EPH
    EPH is offline
    Plumbers Arms member EPH's Avatar
    Jun 2011
    585
    Default
    If you're taking apart something that they've supplied a replacement o ring for then change it and put a fine smear of silicone grease on.
  14. #12
    Jul 2009
    Staffordshire
    2,548
    I would change them all
    Just swap like for like, new seals for old and wipe a smear of silicon grease on each and pop it back in
    Regards
    Tom
  15. #13
    Feb 2010
    YORKSHIRE
    286
    Change them all and be prepared for several attempts as they can be a !!!!! to stop weeping- defying logic sometimes. Had to do several valves, all with very high water pressure and with unvented systems. Their tech help, once you get through, are very helpful.
  16. #14
    Apr 2009
    2,686
    Thanks chaps!
  17. #15
    Apr 2009
    2,686
    Well this didn't go well. Dismantled everything, all came apart ine, neatly lining the parts up on the window ledge in the order they came off, plug in the bathtub incase anything important dropped down, took everything off so all that was remaining was cartridge inside the shower body. Couldn't get it out. Didn't know whether there was something else to undo, scoured all around, felt all around, no grub screws no allen keys, no sirclips, nothing else at all. The cartridge could turn a quarter turn left and right but would not pull out. Put quite a bit of force on it with pair of grips but didn't want to damage it, it wasn't budging.
    There was green scale all over it and it'd been dripping for many months so I was wondering whether it was limescaled into position.
    The only other thing was on the top of the body of the housing (where the red arrow is pointing in attatched picture) there was a hexaganold nut on top of what looked like a fibre washer, different from the one picture but same place. I don't know what this is for and again it wouldn't undo. Might this be the release for the cartridge? I couldn't think what else it might be for unless it's an alternative place for the shower feed to come out of..
  1. Leaky Toilets
    By SimonGW in forum Links, Forum Updates, News and Site Suggestions
    Last Post: 30-06-2011, 08:54 PM
  2. Leaky boiler
    By Net in forum Plumbing Forum
    Last Post: 07-03-2011, 03:41 PM
  3. Sneaky leaky
    By Spudhater in forum Plumbing Forum
    Last Post: 13-07-2010, 08:06 PM
  4. Leaky Pipes
    By peterdeal in forum Plumbing Forum
    Last Post: 09-02-2010, 08:47 PM
  5. leaky tap
    By dnash20 in forum Plumbing Forum
    Last Post: 28-08-2009, 06:05 PM
stop bristan shower dripping
bristan leaking shower
bristan shower leaking
leaking bristan shower
bristan shower leaking problems
bristan shower leak
