Results 1 to 6 of 6
Plumbing & Plumbers Forum - storage tank and L8 issues
Discuss storage tank and L8 issues in the Plumbing Forum at Plumbers Forums; pretty much every single wash basin in my building is outside of the legal temps for L8 readings. At the mains the temp is coming in at 16.4c, in the ...
    Jun 2011
    Exclamation storage tank and L8 issues
    pretty much every single wash basin in my building is outside of the legal temps for L8 readings. At the mains the temp is coming in at 16.4c, in the middle of the tank it's 18.3c, but when I go to the closest point and take the temp it jumps up to 25.5c which is obviously a very dangerous temp for legionella to spread. The hot comes out at around 62.5c but i'm slowly adjusting the boiler until it reaches <60c and I have confidence in that so it's not a problem. What I would like some help with is getting the temps down so they are inside the L8 requirements.
    Q/ how do I lower the temp of the water so it's <20c? -obviuosly as low as possible would be the best-
    Q/ could it be a pump issue? or perhaps the cold pipes are going through a hot spot i.e next to a boiler, is that a resonable assumption??
    any help would be great guys as I'm new to this job title (multi skilled engineer) and i'm a sparky by trade so please don't be haters and help me get this done and dusted,
    kind regards
    Dumbsparky
    AWheating's Avatar
    WestMidlands
    5,803
    Default Re: storage tank and L8 issues
    if the temp is increasing between the tank and the outlet then its got to be picking up heat between the two. Check pipe routes and lag pipework.
    what tpye of system is it?
    Jun 2011
    it's a cold water supply for the wash basin's and cleaners cupboards it feed's 15 wash basin's, 4 showers and about 30 mobile sinks. We are a lab enviroment. I hope this helps im still coming to terms with general terminology as I'm a sparkie.
    Plumbers Arms member Kimou's Avatar
    Jun 2010
    537
    The feed to the tank should be on the opposite side of where the down service is. You could install a destratification pump also.
    Jun 2011
    ok thanks very much guys the lagging does look quite old and it is a very busy part of the plant room, I shall make a recommendation to the client as to install new installation and let you know how it go's, thanks very much.
    uk
    367
    Your tank is gaining nearly two degrees so it needs lagging, or maybe you dont use enough water. Pipes could be oversized. The pipework might run alongside heating pipes. Does the tank just supply cold taps?
  1. Header Tank Issues
    By mcl74 in forum Plumbing Forum
    Last Post: 12-02-2011, 03:09 PM
  2. Storage tank?
    By truemanufan in forum Plumbing Forum
    Last Post: 05-01-2011, 08:42 AM
  3. Storage tank.
    By tom in forum Plumbing Forum
    Last Post: 26-08-2010, 10:19 PM
  4. Immersion tank issues
    By sunnysideup in forum Plumbing Forum
    Last Post: 18-06-2010, 10:00 PM
  5. storage tank??
    By kev42204220 in forum Plumbing Forum
    Last Post: 22-03-2010, 01:16 PM
