Results 1 to 15 of 19
Plumbing & Plumbers Forum - Leak in E7 Ombination cylinder
Discuss Leak in E7 Ombination cylinder in the Plumbing Forum at Plumbers Forums; Hi Folks First experience of working on one of these (luckily its in my bathroom!). Its got a very slow leak, but very difiicult to identify exactly where it is ...-
27-06-2011 #1Plumbing Forum Contributor
- Sep 2010
- 85
- 65
- Thanked 6 Times in 3 Posts
Hi Folks
First experience of working on one of these (luckily its in my bathroom!). Its got a very slow leak, but very difiicult to identify exactly where it is coming from due to foam insulation. What is the general consensus here.. repair or replace (1500x450 is about 365 plus fittings which I could reuse some). Repair would obviously be cheaper..would I need to remove some of the insulation to identify the leak? All advice greatly received.
27-06-2011 #2Moderator
- Nov 2007
- hythe hampshire
- 8,983
- 447
- Thanked 747 Times in 727 Posts
Re: Leak in E7 Ombination cylinder
first thing to do is check all the fittings going into the cylinder possibly coming from one of them.
The Following User Says Thank You to steveb For This Useful Post:
smudger (27-06-2011)
27-06-2011 #3Plumbing Forum Contributor
- Sep 2010
- 85
- 65
Will go and do it now (well, when I've had me coffee!)
27-06-2011 #4Plumbing Forum Contributor
- Sep 2010
- 85
- 65
Hi. Just had a look. The water is accumulating at the base of the cold water feed from the f&e tank, where it enters the cylinder. However, due to the insulation and awkward access I'm not certain whether it is coming from the joint at the f&e tank or from the joint into the cylinder. The pipe is wet for at least 100mm up from the joint which suggests it is running down. Both the joints are pre-fabricated. Is it possible to drain down and repair by resoldering the joints?
27-06-2011 #5UK Plumbersforums Trusted Advisor.
- Dec 2010
- WestMidlands
- 5,839
- 124
remove the cylinder and take it from there.
The Following User Says Thank You to AWheating For This Useful Post:
27-06-2011 #6UK Plumbersforums Trusted Advisor.
- Oct 2010
- Northampton
- 6,058
- 595
- Thanked 290 Times in 280 Posts
or get professional to have a look
27-06-2011 #7Plumbing Forum Contributor
- Sep 2010
- 85
- 65
Yes, thanks for that. I think the cylinder was installed then a cupboard built around it. The only way to get the cylinder out is to move the loo and dismantle the cupboards. Why can't anything ever be straight-forward!!
27-06-2011 #8Plumbing Forum Contributor
- Sep 2010
- 85
- 65
Depends what you mean by professional really. I'm NVQ L2, water regs, unvented but lack experience on these. Hence the question. Many "professionals" with much more experience than me have said they can't be repaired and should just be replaced. We are intending to move bathroom in about 6 months and won't want combi-cylinder so would rather fix.
27-06-2011 #9Plumbers Arms member
- Jan 2008
- Hants
- 965
- 34
- Thanked 111 Times in 109 Posts
As it's your own cylinder, cut off as much insulation as you can to get a good look and then cover where you think it's leaking from with lsx.
That might buy you a few months !
The Following User Says Thank You to BLOD For This Useful Post:
27-06-2011 #10Plumbing Forum Contributor
- Sep 2010
- 85
- 65
Great, thanx BLOD. Only need a couple of months and, as you say, its in my own house. However, as I'll have to demolish half the bathroom to get the little monkey out, may be worth putting in a new one as I don't fancy doing it again in a hurry. But thanks for the help.
28-06-2011 #11UK Plumbersforums Trusted Advisor.
- Dec 2009
- Coatbridge, Lanarkshire
- 3,515
- 52
- Thanked 342 Times in 315 Posts
first thing to check is the overflow connection to see if the ball valve is overflowing and the fitting leaking as it has never been tightened properly, quite a common fault and easy to fix
The Following User Says Thank You to kirkgas For This Useful Post:
smudger (28-06-2011)
28-06-2011 #12
Wrap the connection fittings in some tissue and see if they dampen. Start high work low. That doesn't mean have a joint and work on your knees.
28-06-2011 #13Plumbers Arms member
- Jan 2011
- MOLD, N Wales
- 276
- 7
- Thanked 17 Times in 16 Posts
The Following User Says Thank You to Ian10261 For This Useful Post:
28-06-2011 #14
28-06-2011 #15Plumbers Arms member
- Jan 2011
- MOLD, N Wales
- 276
- 7
New Oil Boiler and Unvented cylinder cylinder required
By chris1943 in forum Looking for work.Replies: 12Last Post: 03-06-2011, 08:30 PM -
Leak from DHW cylinder connection
By Foxtrot Oscar in forum Plumbing ForumReplies: 20Last Post: 25-04-2011, 12:43 PM -
Cylinder Stat for small Hw Cylinder
By geron in forum Plumbing ForumReplies: 2Last Post: 26-05-2010, 05:47 PM -
Cylinder leak on 1500x450 .
By verdigrey in forum Plumbing ForumReplies: 8Last Post: 15-02-2010, 06:42 PM -
Unvented cylinder leak
By Powderkeg in forum Plumbing ForumReplies: 17Last Post: 09-03-2009, 08:23 AM
6Likes
fridge magnets
