Results 1 to 10 of 10
Plumbing & Plumbers Forum - Safety, sealed central heating
Discuss Safety, sealed central heating in the Plumbing Forum at Plumbers Forums; Is it law that a sealed central heating system needs a minimum level of interlock from a safety point of view I know the answer is yes from an efficiency ...-
27-06-2011 #1Banned
- Jul 2010
- 68
- Thanked 3 Times in 2 Posts
Is it law that a sealed central heating system needs a minimum level of interlock from a safety point of view I know the answer is yes from an efficiency point of view, came across a sealed central heating system today with no room thermostat. The way I see it is there is no means to shut down the boiler once the room is at temperature, therefore the water in system will expand until the PRV blows or th boiler over heats right?
27-06-2011 #2Plumbers Arms member
- Dec 2010
- 1,407
- 103
- Thanked 104 Times in 103 Posts
Re: Safety, sealed central heating
Boiler thermostat will shut it down. It need a PRV and an overheat stat to conform to the regs.
27-06-2011 #3UK Plumbersforums Trusted Advisor.
- Dec 2010
- WestMidlands
- 6,047
- 125
- Thanked 593 Times in 565 Posts
boiler stat?
27-06-2011 #4Steady Plumbing Forum Contributor
- Jun 2010
- 110
- Thanked 7 Times in 7 Posts
the boiler will have its own heating thermostat which the user can normally set, normally between 60-85 ish
(normally the heating return temp)Last edited by emerald; 27-06-2011 at 06:25 PM.
27-06-2011 #5Plumbers Arms member
- Dec 2010
- Devon
- 605
- 16
- Thanked 83 Times in 68 Posts
The boiler stat will stop it before then.When the boiler switches off the water will cool and the pressure will drop,obviously a room stat should be fitted,but that's for efficiency only(Building Regs Part L). The PRV and overheat stat are the safety net.
27-06-2011 #6UK Plumbersforums Trusted Advisor.
- Apr 2011
- Newcastle Upon tyne
- 6,116
- 306
I believe a central heating boiler and system will need the minimum of:
1) fan flow proving device
2) Pump flow proving device
3) Flame ignition/maintenance proving device
4) water flow temperature control
5) water flow temp o/heat cut off device
6) system pressure relief valve
7) a means of taking up water expansion
And - anything else i left out!
27-06-2011 #7UK Plumbersforums Trusted Advisor.
- Dec 2010
- Bridgend, Wales
- 3,609
- 69
"nothing is impossible"
27-06-2011 #8UK Plumbersforums Trusted Advisor.
- Apr 2011
- 6,116
- 306
Really SimonJohn? Weyabuggaman!
27-06-2011 #9Steady Plumbing Forum Contributor
- Mar 2011
- 241
- Thanked 16 Times in 15 Posts
Not all sealed systems are on a fan flued boiler,so aps not needed.The pump can be outside the boiler,so proving switch not needed.Point 4 would be the boiler stat?
27-06-2011 #10UK Plumbersforums Trusted Advisor.
- Apr 2011
- 6,116
- 306
Replacing central heating and water heating - advice please
By sylan in forum Central Heating ForumReplies: 7Last Post: 03-01-2011, 07:13 PM -
Immediate Loss of Pressure in Sealed / Pressurized Central Heating System
By ashimashi in forum Central Heating ForumReplies: 10Last Post: 10-12-2010, 02:01 AM -
Sealed Central Heating Systems
By Paul Cockhill in forum Central Heating ForumReplies: 4Last Post: 26-11-2009, 11:17 PM -
hot water not heating but central heating working???
By bigd111 in forum Plumbing ForumReplies: 7Last Post: 09-04-2009, 03:58 PM
1Likes
Advice on buying an on-demand 12v...
