Results 1 to 12 of 15
Plumbing & Plumbers Forum - Accumulators? Simple???
Discuss Accumulators? Simple??? at UK Plumbers Forums; Are accumulators as simple as redirecting the mains from the unvented cylinder thru the accumulator then back into the pressure reducing valve to the cylinder giving equal pressure accross hot ...
    Jun 2010
    spalding, lincolnshire
    93
    Default Accumulators? Simple???
    Are accumulators as simple as redirecting the mains from the unvented cylinder thru the accumulator then back into the pressure reducing valve to the cylinder giving equal pressure accross hot and cold??
    Or am i missing something?
    If you notice this notice, you'll notice this notice is not worth noticing
    Super Moderator
    steveb's Avatar
    Nov 2007
    hythe hampshire
    12,859
    Default Re: Accumulators? Simple???
    it's so you can boost the pressure by use of a pump on the mains i think
    Jun 2010
    93
    Default
    Im looking at one without a pump. Iv got 3 bar and 14 lmin but it on 15mm mains. Looks to me like you jus run the mains thru it to the accumulator. With non return valves.
    Plumbers Arms member secret squirrel's Avatar
    Feb 2009
    Essex
    2,531
    I made a few enqs on these a while ago. Can't remember the company but they were very helpful. You have to connect it to the mains after the kitchen tap. You then need to set the pressure at whatever the highest pressure of the house is. you need to test the pressure at varying times of the day. if the highest pressure is 2.5 bar then you can set it at 2.5. That is the pressure you'll get. Apparently.
    Oct 2010
    8,607
    mains in to acumulator mains out to pressure reducing valve and then to unented cylinder ,the job of acumolator is to maintain same pressure during peak and off peak hours ,works good the one i fit could not adjust it but did good job
    Jan 2008
    Hants
    1,304
    They are just a large expansion vessel (for potable water)
    I've fitted a few with good results, main problem I've found is having a space large enough to install them.
    I haven't fitted the GAH one's but they have a decent diagram on the link below
    http://www.gah.co.uk/downloads/GAH-c...m-2010-Feb.pdf
  7. The Following User Says Thank You to BLOD For This Useful Post:
    Jun 2010
    93
    Default
    Thanks blod. Thats the sort of thing iv been looking for. I had it in my mind roughly how that looks. In gonna get a horizontal one an stick it in the loft i think. Ill lift all the insulation from under it an jus lay it over so it shouldnt freeze.
    Jan 2008
    Hants
    1,304
    If you've got a small loft hatch you can fit smaller ones in series. Advanced water have a good selection of different sized ones.
    stevetheplumber's Avatar
    east london
    10,613
    i was told recently these dont comply with water regs as they are effectively a dead leg
    Jan 2008
    Hants
    1,304
    I'd agree they are a dead leg, but would that then mean all the unvented cylinders fitted with expansion vessels don't comply with regs either ?
    mutley racers's Avatar
    Jun 2009
    Hampton court, Surrey
    4,311
    Quote Originally Posted by BLOD View Post
    Great link
  13. #12
    Riley's Avatar
    Sarf Coast
    6,381
    Cheers Blod really really plain and simple
  1. Connecting Accumulators
    By Wayne Campbell in forum Renewable Energy
    Last Post: 21-03-2013, 09:13 PM
  2. Cold water expansion vessels/accumulators
    By zeebeedee in forum Plumbing Forum
    Last Post: 25-04-2012, 05:56 PM
  3. Some simple questions... if you know the answers?
    By Riverside in forum Central Heating Forum
    Last Post: 15-11-2011, 09:08 PM
  4. Why just a simple Why
    By unguided1 in forum Plumbing Forum
    Last Post: 22-04-2011, 11:49 AM
  5. Simple college question
    By Mr learner in forum Plumbing Forum
    Last Post: 09-02-2011, 01:21 AM
  6. simple one
    By cjg in forum Central Heating Forum
    Last Post: 27-12-2010, 10:08 PM
  7. a simple answer...please
    By jackH in forum Gas Safe Register Forum - Public Forum
    Last Post: 26-12-2010, 02:12 PM
  8. Simple ch problem?
    By delbox in forum Central Heating Forum
    Last Post: 11-05-2010, 06:58 PM
accumulator for unvented cylinder
accumulator for unvented system
plumbing a accumultor to mains
mains accumulator 15mm mains
connecting accumalator to unvented
