Results 1 to 2 of 2
Plumbing & Plumbers Forum - Test pump
Test pump
Discuss Test pump in the Plumbing Forum at Plumbers Forums; a mate is selling a MANUAL PRESSURE TEST PUMP really cheep is it wrth me buying it how is it used i know its used on new pipe work lol...-
30-05-2011 #1Top Plumbing Forum Contributor
- Aug 2010
- 376
- Thanked 1 Time in 1 Post
Test pump
30-05-2011 #2UK Plumbersforums Trusted Advisor.
- May 2008
- Bolton
- 4,190
- 190
- Thanked 352 Times in 332 Posts
Re: Test pump
you fill it with water connect the hose onto pipework, pump handle to 1.5 x normal working pressure then leave for a bit and check for drop in pressure. probably worth buying if cheap enough new they go for about a ton.
alternatively you could cobble together an air test pump from a footpump and a tyre valve
Soundness test
By skaly in forum Gas Safe Register Forum - Public ForumReplies: 17Last Post: 01-01-2011, 04:28 PM -
how to test gas grill?
By bluesky in forum Gas Safe Register Forum - Public ForumReplies: 6Last Post: 30-12-2010, 12:47 PM -
pressure test
By still learning in forum Plumbing ForumReplies: 3Last Post: 21-02-2010, 11:43 PM -
What will be involved in the test?
By KWCFC in forum Plumbing CoursesReplies: 8Last Post: 15-06-2009, 01:11 AM -
By KWCFC in forum Plumbing ForumReplies: 6Last Post: 07-06-2009, 04:32 PM
Hello from totally new plumber
9 Minutes Ago in New Member Introductions
