Results 1 to 2 of 2
Plumbing & Plumbers Forum - Redring pumped thermostatic shower
Discuss Redring pumped thermostatic shower in the Plumbing Forum at Plumbers Forums; My question is that I have a redring pumped electric thermostatic shower which is installed. In a 2 storey house the pipework to shower is via the roofspace in which ...-
24-05-2011 #1Plumbing Forum Contributor
- May 2011
- 39
- 12
My question is that I have a redring pumped electric thermostatic shower which is installed. In a 2 storey house the pipework to shower is via the roofspace in which cold has separtate supply from storage tank .hot water supply to shower direct from hot water cyl my problem is on a couple of occasions the hot and cold pipework has become airlocked the height of the storage tank to. Shower pipework is approx 300mm why would this pipework become air lock this happens every couple of weeks once I take filters of at shower to flush pipework water supply becomes perfect some solutions would be good
03-06-2011 #2New to Plumbing Forum
- Jun 2011
Re: Redring pumped thermostatic shower
More than likely it is the pipe run of the hot supply that is causing the airlock. You will need to check that the pipework is copper, it doesn’t have any sweeping bends and it is in the right position on the vent pipe.
Shower Pump, Digital pumped Shower, Venturi Valve, Electric?? Im so confusedd!!
By dcuk in forum Bathrooms, Showers and WetroomsReplies: 6Last Post: 13-02-2011, 06:10 PM -
pumped shower
By welly2510 in forum Plumbing ForumReplies: 17Last Post: 14-01-2011, 11:52 PM -
Converting Gravity Hot Water & Pumped Heating to Fully Pumped System
By T&Earth in forum Central Heating ForumReplies: 3Last Post: 16-12-2010, 06:34 AM -
Redring Powerstream to fill a BATH??
By kyra in forum Plumbing ForumReplies: 5Last Post: 27-03-2010, 08:02 PM -
Pumped Shower, NO Hot Water
By Pedro69 in forum Bathrooms, Showers and WetroomsReplies: 5Last Post: 25-12-2009, 12:48 PM
Twitter
7 Minutes Ago in General Off-Topic Chat
