Results 1 to 8 of 8
Plumbing & Plumbers Forum - Isolation valves
Isolation valves
Discuss Isolation valves in the Plumbing Forum at Plumbers Forums; Hi All, Does any one know of a supplier/manufacturer of 22mm compression X 1/2 inch BSP female isolation/service valves. I don't have enough room to install normal reducers and 22mm ...
    Plumbing Forum Contributor
    Aug 2010
    41
    Default Isolation valves
    Hi All,
    Does any one know of a supplier/manufacturer of 22mm compression X 1/2 inch BSP female isolation/service valves. I don't have enough room to install normal reducers and 22mm x 22mm or 15mm x15mm valves.
    Cheers
    Oct 2008
    685
    Default Re: Isolation valves
    You should be able to fit a 22mm valve and use a fitting reducer to one side probably smaller with end feed. Basically the 22mm end of the reducer goes straight into the valve fitting leaving a 15mm socket for your pipe.
    AWheating's Avatar
    WestMidlands
    5,838
    might find something in the BES catalogue?
    Aug 2010
    41
    Quote Originally Posted by tackleburger View Post
    Sorry mate that option is too long, not enough room, especially as I'll need a 15mm x 1/2 inch female adapter as well. The closest I can find is 3/4 female x 3/4 female valve fitted with a 22 x 3/4 male adapter in one end and a 3/4 male x 1/2 female adapter the other.
    Any idea how long a 3/4 x 3/4 female/female valve is, I haven't been able to find any dimensions yet.
    Like the username - I've heard of a helmet (helmut) burger but not a tackleburger
    Cheers.
    Aug 2010
    41
    I looked in there, I think that's where I found 22 x 15 and 22 x 1/2 " male valves but no female 1/2"
    Thanks anyway.
    system3's Avatar
    Feb 2010
    Alloa, Scotland
    7,069
    Can't you use a brass reducing bush over the thread on the end you want reduced? Any merchant sells them.
    steveb's Avatar
    Nov 2007
    hythe hampshire
    8,983
    what about using a three part compression reducer to fit in the end of the 22mm iso valve to take 15mm one side and 22mm the other.
    bobgarden's Avatar
    May 2011
    62
    If BES dont have it you'll strugle to find um. how about what the last 2 guys said with bushes and reducers etc
  1. vaillant 824/1 E isolation valves
    By stiffl in forum Central Heating Forum
    Last Post: 01-10-2010, 05:11 PM
  2. imperial to metric and isolation valves?
    By rabu in forum Plumbing Forum
    Last Post: 06-07-2010, 08:18 PM
  3. Why Aren’t Isolation Valves Compulsory?
    By uug197h in forum Water Regulations
    Last Post: 13-12-2009, 10:53 AM
  4. Gate valves for general isolation use
    By alexp78 in forum Plumbing Forum
    Last Post: 05-10-2009, 05:00 PM
  5. isolation valves?
    By secret squirrel in forum Plumbing Forum
    Last Post: 25-09-2009, 08:27 AM
bsp female isolation valve
isolating valve with reducers
isolating valve 15mm one end and 12 the other
22mm x 34 male isolation valve
plumbing isolation valve female and male ends
service valve 15mm copression-12bsp male
isolating valve male and female
