Cheers Graham.
Although I don't understand in full your first point. If pump over occurs you say water in the heating circuit could or would be unnecessarily pushed up the vent pipe even to the point where it could find itself back in the F&E tank or cistern? As a result of that the heating circuit would require replenishment to the approx. volume of water lost. This new water from the F&E tank/cistern is oxygenated and as such will cause undesirable corrosion within the system. Yes? The only part I'm missing then is what the above has to do with the 150mm max. distancing? What is the significance?
