Old 03-02-2008   #1 (permalink)
atakd
View atakd's Photo Album
Default low pressure from hot water cylinder
Hi
I have just fitted a bath shower mixer taps I have plenty of cold water pressure but the hot water comes from a cylinder which is on the same level this has no pressure to function the shower. Is there any pumps that I can buy that will increase the overall hot water pressure from a gravity fed tank.
thanks kate
atakd is offline   Reply With Quote
Old 03-02-2008   #2 (permalink)
uug197h
View uug197h's Photo Album
Default Re: low pressure from hot water cylinder
how much pressure was there before the new mixer? has the mixer been put on its own feed from the tank and not just conected to the standard pipe work?
Plumbing Forum Moderator
Old 03-02-2008   #3 (permalink)
atakd
Thanks for the question
I am not sure how much pressure there was before. I think the cold comes in from mains and hot comes from cylinder.
Old 03-02-2008   #4 (permalink)
ProffesorPlumb
You need to make sure that the hot supply to the shower has come off a 'surrey' flange or an 'essex' flange if it is going to a thermostatic valve. You also need to ensure that the valve supports low pressure water flow.
The pipework from the hot tank will need to be installed correctly as you may find you will have an air gap from the cylinder to the valve, causing the water to 'trickle' through the hot pipe.
You can get single impeller pumps that will pump the water, but normally that only applies to areas where overall water pressure (cold) is low.
Check the compatability of the shower valve before diagnosing any faults with the installation.
Old 04-02-2008   #5 (permalink)
atakd
thanks for the advice I think I will have to get plumber in
Old 03-06-2008   #6 (permalink)
greenday
View greenday's Photo Album
be sure to always fit a thermostatic valve, as incorrect instalation of the cwsc can result in scalding!!!
greenday is offline   Reply With Quote
Old 19-06-2008   #7 (permalink)
Eddie Bergin
View Eddie Bergin's Photo Album
Yes A shower Pump
Eddie Bergin is offline   Reply With Quote
: How can you increase the Water Pressure ? neco Plumbing Forum 7 06-06-2008 06:09 PM
Hot water pressure low after installign shower Unregistered Plumbing Forum 0 28-01-2008 05:38 PM
How can you increase the Water Pressure ? nylees Plumbing Forum 0 28-11-2007 12:37 PM
External Links: Loans : Debt Loans : US Business Directory : Buy WoW Gold : Credit Card
Electrical Help
Tiling News
Tiling NVQ
Tilers Tools
Tiling Network
Electricians Forum
Conservatories UK
Tile Forum
Search Engine Optimisation
Tile Pages
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21
