Plumbing & Plumbers Forum - 10 mm copper pipe
10 mm copper pipe
Discuss 10 mm copper pipe in the Plumbing Forum at Plumbers Forums; Has anyone got any tips on how to bend 10mm copper either with a mini hand bender or springs...-
11-04-2011 #1New to Plumbing Forum
- Oct 2009
- wrexham
- 18
- 17
10 mm copper pipe
11-04-2011 #2UK Plumbersforums Trusted Advisor.
- Apr 2008
- South Shropshire
- 6,039
- 501
- Thanked 676 Times in 610 Posts
Re: 10 mm copper pipe
I use a bender. Nothing to it really although occasionally a bend is a little wonky. Only "tips" are:
a) Cut a little longer piece than you need, then bend, then cut to size - unless you're so fantastic that a quick measure gives you a bend in EXACTLY the right place, every time. Everyone on this forum is brilliant at this so it's probably just me.
b) Bend the pipe slowly and make sure it doesn't slip in the benders. I find if I yank it round quickly then the bend deforms and the outside flattens rather than staying in a rounded shape.
If you're new to 10mm pipe then this might be useful:
Using a 10mm pipe cutter instead of a hacksaw.
If using a 15mm-10mm compression fitting then ensure this it squarely over the end of the pipe and pushed well into the radiator valve (and holding it there) before tightening.
Using my hands and thumbs when making small curves in the pipe.
With 10mm olives tighten joint rather more than hand tight but don't force the joint at all. If you have a small seep then usually some more tightening sorts it out. If you tighten it too much to begin with then you risk deforming the olive too much so it won't be water tight no matter how much you tighten it afterwards.
When fitting 10mm for oil you need an oil sleeve nowdays (to keep OFTEC happy). You'll also find that using a sleeve you can tighten the join much more than normal so be more certain of an oil tight joint before you turn the oil on again.
Hope this post hasn't been too patronising.
The Following 2 Users Say Thank You to dontknowitall For This Useful Post:
GQuigley67 (11-04-2011),karlhayes (11-04-2011)
11-04-2011 #3UK Plumbersforums Trusted Advisor.
- Oct 2010
- Glasgow, Scotland
- 4,696
- 324
- Thanked 260 Times in 254 Posts
some useful tips DKIA, I myself haven't used 10mm alot
The Following User Says Thank You to GQuigley67 For This Useful Post:
dontknowitall (11-04-2011)
11-04-2011 #4UK Plumbersforums Trusted Advisor.
- Jan 2008
- North Yorkshire
- 4,149
When fitting a 10/15mm reducing set ALWAYS use a few wraps of PTFE round the olive and round the but which goes into the 15mm fitting. Always use a 10mm insert so you can screw the fitting up tight without deforming the pipe.
The Following User Says Thank You to WHPES For This Useful Post:
karlhayes (13-04-2011)
11-04-2011 #5uɐɯ sɐƃ moderator
- Jan 2010
- maesteg,south wales
- 13,314
- 827
- Thanked 1,264 Times in 1,207 Posts
the easiest way to bend 8mm or 10mm is easy just buy a quality minibore bender not a cheap one off ebay
GASMAN
The Following User Says Thank You to gas man For This Useful Post:
Copper pipe
By stevew451 in forum Central Heating ForumReplies: 9Last Post: 19-01-2011, 08:51 PM -
10mm copper pipe or 8mm pipe measurements
By dsd7037 in forum Plumbing ForumReplies: 8Last Post: 12-01-2011, 10:03 AM -
How to cut copper pipe
By mani in forum Plumbing ForumReplies: 18Last Post: 02-06-2010, 11:51 AM -
copper pipe
By REDSAW in forum Plumbing ForumReplies: 4Last Post: 23-04-2010, 09:55 PM -
Cement over copper pipe.
By pacorio in forum Plumbing ForumReplies: 5Last Post: 26-03-2010, 11:12 PM
1Likes
Incompetent Plumber and SNIPEF
