Results 1 to 2 of 2
Plumbing & Plumbers Forum - Honeywell ST6400C Control - timer issue
Discuss Honeywell ST6400C Control - timer issue in the Plumbing Forum at Plumbers Forums; Hi, I have a gravity fed central heating system, which has a Honeywell ST6400C 7 day programable time. This has seperate zones for HW & CH/HW, throughout the winter the ...-
10-04-2011 #1New to Plumbing Forum
- Apr 2011
- 4
Hi, I have a gravity fed central heating system, which has a Honeywell ST6400C 7 day programable time. This has seperate zones for HW & CH/HW, throughout the winter the control has been set for HW - continuous and CH - programmed to come on in am and evening and has been working well. When switch to HW - continous and CH - off the unit still seems to be running the Grundfos Alpha+ central heating pump at the programmed times of the day, however, it is not heating the radiators. How can I stop it running the pump, which is more of an annoyance than anything else?
11-04-2011 #2Plumbers Arms member
- May 2009
- 7,303
- 218
Re: Honeywell ST6400C Control - timer issue
You probably have a fully pumped system therefore pump is needed to heat the hot water as well as the heating,if pump is loud or annoying maybe not secured correctly,air in the pump or new pump maybe required, as soon run very quietly
The Following User Says Thank You to Puddle For This Useful Post:
ajtomlins (11-04-2011)
Problem with honeywell st6400c??
By cap1000 in forum Central Heating ForumReplies: 4Last Post: 03-01-2011, 07:30 PM -
Honeywell Timer setting.
By Steven Williams in forum Central Heating ForumReplies: 2Last Post: 12-11-2010, 10:15 AM -
By gardencityserv in forum Central Heating ForumReplies: 2Last Post: 29-09-2010, 06:55 PM -
Ideal classic RS50 with Honeywell control
By George Owenson in forum Central Heating ForumReplies: 20Last Post: 23-09-2010, 08:36 PM -
Honeywell CM927 timer
By gavsdad in forum Central Heating ForumReplies: 2Last Post: 17-01-2010, 03:51 PM
what is it ?
16 Minutes Ago in General Off-Topic Chat
