Results 1 to 12 of 23
Plumbing & Plumbers Forum - Pump fitted to mains
Discuss Pump fitted to mains at UK Plumbers Forums; Hi all, Really great to be treated to your hands-on experience. Thanks. I'm not a plumber, but I am a mechanical engineer working on fluid systems, which is similar, and ...
    Default Pump fitted to mains
    Hi all,
    I'm not a plumber, but I am a mechanical engineer working on fluid systems, which is similar, and I've come across something that confuses me.
    My plumber explained that he cannot connect pump to the mains water supply to supply a shower (the hot water comes from a tank so is OK). I accept this may be the case, but why?
    Is it because of the mains pressure being a bit high for pump inlet (they are typically max 1 bar)? Is it a 'catch-all' reg to stop someone abusing the mains supply (in which case it doesn't really apply to one shower). Is it something else?
    I stress I'm not looking for a reason to cheat the reg, but I genuinely don't understand the technical reason for the ban. Can you help?
    Max
    Howsie's Avatar
    Surrey
    5,208
    Default Re: Pump fitted to mains
    You can draw upto 12l/m from the mains via a pump so I guess you'd be OK for the shower. Anymore than this and the WU would have a problem getting the minimum pressure to the rest of the community.
    fuzzy
    you couldnt be allowed to pump mains as you could draw more water from the main than you should and starve other properties of water. you could even, if the pump was strong enough create a situation you draw water from somebody elses water from their property
    Quote Originally Posted by fuzzy View Post
    Thanks, guys.
    So given the original idea was to pump a shower, there is no pure technical reason why you can't pump the mains, just a catch-all reg? After all, one shower couldn't starve a neighbouring property. If you think of the relative pipe sizes etc, a normal shower pump motor (<0.3KW) would burn out long before you sucked water that volume of water thru' a 15mm pipe!!
    I thought it may be the case that it was just a catch-all reg, as I cannot think of a technical reason, but it's good to see you guys agree.
    Sep 2010
    100
    its to prevent contamination of the water supply in the unlikely event that say the water board had turned off the streets water supply and next door are filling the pond with a hose with no check valve on and you turn on your shower and pull dirty water from the pond into the water main.
    Sep 2010
    The 'Tropical' South
    184
    Quote Originally Posted by PlumbingSucks View Post
    spot on! water companies say that only a small drop in mains pressure for a short period of time can create backflow conditions. They estimate this happens every few minutes around the country and can be due to a number of things. remember also you can only 'pull' whats available and your mains pipework will have a limit on what you can pull in.
    Oct 2010
    74
    I think also, if you pump mains water it can cause dirt and mud to get sucked into the mains pipe if there is a crack in the pipe. obviously contaminating the main supply.
    fuzzy
    i wouldnt call it a catch all reg, lots of things can affect pressure, if you have any type of pump pulling it could cause back flow and therefore contamination. you cannot fir a pump to the mains. you need a cistern and therefore an air gap
    Howsie's Avatar
    Surrey
    5,208
    Default
    I understood that you could pump the mains upto 12l/m and then after that you had to seek approval from the WU.
    Jan 2008
    North Yorkshire
    4,777
    If you are wanting a mixer shower fitting then it is incorrect to have unbalanced hot and cold. The correct way is to bring the cold feed from the DHW cistern in the loft. If supply is a problem you need to change your cistern for a larger one.
    Mar 2009
    64
    Quote Originally Posted by Howsie View Post
    I don't think so - I thought the only way to pump the mains and comform with the water regs is to have a breaker tank & pump that
    ecowarm's Avatar
    Mar 2010
    lincolnshire
    3,748
    I have fitted this before Grundfos UPA 15/90 Home Booster Pump with water board approval
  1. Salamander Mains Water Pressure Pump £210.00
    By hussy in forum For Sale & Wanted
    Last Post: 16-10-2013, 01:53 PM
  2. salamander Mains pump?
    By still learning in forum Plumbing Forum
    Last Post: 17-07-2013, 09:28 PM
  3. Shower Pump - tank fed hot - mains fed cold
    By Plumb-pro in forum Plumbing Forum
    Last Post: 17-01-2013, 06:08 PM
  4. Cold Mains Booster Pump
    By tolly in forum Plumbing Forum
    Last Post: 19-12-2012, 05:03 PM
  5. Can i have a shower pump fitted?
    By andyken09 in forum Plumbing Forum
    Last Post: 28-11-2012, 07:17 PM
  6. Replies: 1
    Last Post: 17-10-2012, 10:42 AM
  7. Two ball valves fitted to one tank, low mains presure
    By andrew1 in forum Plumbing Forum
    Last Post: 30-05-2012, 09:22 PM
  8. Replies: 13
    Last Post: 17-01-2011, 03:10 PM
  9. Help..New pump fitted, not pumping?
    By bob-the-wrecker in forum Central Heating Forum
    Last Post: 11-04-2009, 04:31 PM
can you pump mains water
fitting a pump to mains water
why is it illegal to pump cold water mains
is it dangerous to put a pump on the mains water supply uk
can you pump water from the mains
