Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
Plumbing & Plumbers Forum - vokera compact 25 only works with case off
Discuss vokera compact 25 only works with case off in the Plumbing Forum at Plumbers Forums; yep,both are Italian brands by any chance?...
  1. #16
    uɐɯ sɐƃ moderator
    gas man's Avatar
    maesteg,south wales
    13,319
    Default Re: vokera compact 25 only works with case off
  2. GASMAN
    IMPOR
  3. #17
    tamz's Avatar
    Scotland
    9,348
    Quote Originally Posted by gas man View Post
    Well both of them will take you on a trip around the Ferrari factory if you buy enough............could just be a coincidence .
    They both actually do(used to) really good trips. Been on 3 of them.
  4. #18
    Feb 2010
    pelsall
    412
    had similar fault on a ferroli a few years back,turned out the fan was not runnung at full capacity.
  5. #19
    Sep 2010
    @ LEEAGAR
    Is there any remedy found? Was the restrictor OK? Please reply as you will be helping numerous others.
    This seems to be a common issue on these boilers (sabre/vokera)
  6. #20
    Plumbing Forum Contributor
    Jun 2011
    77
    Got the same problem, did you manage to sort yours?
  7. #21
    New to Plumbing Forum leedsgasservice's Avatar
    Leeds
    12
    Had the same problem on a sabre. There wasn't enough differential across the fan. If you remove one hose from the aps then the boiler worked fine. Cleaned latent hx and replaced fan,all good.
    LGS-LEEDS GAS SERVICES
  8. #22
    Jun 2011
    77
    Hi, if you look back on old threads I had exactly the same problem, I rang Vokera and they were most unhelpful, no matter what I did I couldn't get the boiler to fire with the case on. All the could tell me was that I had an air flow problem. I gave up in the end and told the landlord to call Vokera out. I will call the tenant later and see if they managed to fix it. The only thing I didn't do was to remove the flue restrictor, if there is one or clean the heat exchanger with a blade. The boiler has aslo run for a couple of years without any problems. Let me know if you get yours going,
    Cheers, casaco
  9. #23
    Jan 2012
    I'd go with replacing the venturi as previously mentioned as only a tiny build up of debris is needed to give a low differential across the aps (top venturi normally at fault it can also get dirt into shaft which cant be seen and needs a small screwdriver to clean)
  10. #24
    Jun 2011
    77
    I polished the inside of the venturi with emery cloth until it looked brand new, including the shaft, it still won't run unless the front case is opened.
  11. #25
    Leeds
    12
    Try cleaning out the tappings where the rubber tubes connect to the fan or flue.As mentioned use a small screw driver and some compressed air.
  12. #26
    Jan 2012
    The front casing isnt squashing the silicone tubes or the tubes are holed? If its had a new aps check that the small (tiny) screws have been used to connect the bracket to the aps otherwise it may have punctured the casing. One other thing you can try is remove the rolling pin shaped cylinder out of the latent heat exchanger (if fitted). Cant think of anything else to try.
  13. #27
    Dec 2008
    23
    Came across with same problem, did clean everything out, dismantled flue to check the pass ways. All clean, hoovered out latent hx, fan clean. APS seems to be working correctly as managed to get the boiler firing with the case closed for some time. It used to run with case on until hot, then could not fire up again for a while. Same story - about 3 years old. Still not running. Any of you managed to get it up and running? I shall try to replace venturis if can source quickly ones, also suspecting a fan is not spinning fast enough. There is no sign of wear tho, bearings looking spot on, smooth spin, no noise just doesn't work for no reason.
  14. #28
    Jan 2012
    Have replaced a few fans lately having done the venturis first but you can normally tell that the fan sounds weak.
  1. vokera compact pcb
    By rm1 in forum Central Heating Forum
    Last Post: 17-12-2011, 10:59 AM
  2. Vokera Compact HE
    By AllyBongo in forum Central Heating Forum
    Last Post: 30-03-2011, 08:04 PM
  3. vokera compact 28
    By marleyco in forum Central Heating Forum
    Last Post: 18-01-2011, 11:43 PM
  4. Vokera compact HE
    By peteisfishing in forum Central Heating Forum
    Last Post: 19-11-2010, 03:30 PM
  5. Any one have a simple answer to how torbeck compact valve works
    By Readingplumber in forum Valves & Taps
    Last Post: 20-10-2008, 09:38 AM
boiler only works with cover off
boiler only fires cover offvokera compact 25 problemsvokera compact 25he reviewvokera 25 compact fan venturiboiler only works with case offboiler only works cover off
