Results 1 to 10 of 10
Plumbing & Plumbers Forum - Shower question
Shower question
Discuss Shower question in the Plumbing Forum at Plumbers Forums; evening all, Went to see a customer today and he has a shower issue. it is a seperate enclosed shower that has been tiled in and looks very pretty, no ...
    Oct 2009
    758
    Default Shower question
    evening all,
    Went to see a customer today and he has a shower issue. it is a seperate enclosed shower that has been tiled in and looks very pretty, no ball'o'fixes (typical) so cant isolate but can via the mains.
    The water has soaked from the shower and into the downstairs livingroom. Whwn I got there the aa had isolated the water and the ceiling had begun to dry, i checked the silicone and all seems good so no seepage round the seals.
    This leaves the question - could the shower be leaking where is is chased into the wall/ties into the valve or could it be the "guts" thats need replacing (rubbers etc), like i say it is tilled in with no access - why would it leak when the valve is on and there is call for water but holds when off?
    The shower is a Sirius TS1700, not a fan of tiled in appliances buts thats life I guess.
    Ta
    Bexhill, East Sussex
    112
    Default Re: Shower question
    Could be the waste?
    Oct 2009
    758
    was pouring bucket after bucket for near 30 mins down the waste and not a bean
    112
    Is the shower hose exposed or is it a concealed riser? Any chance of opening up a hole in through the back wall?
    Oct 2009
    758
    totally concelled mate, i think i should remove a couple of tiles but i'm clumsy and i break 17 for every 1 removed.
    mjt
    mjt is offline
    Nov 2009
    Lincolnshire
    316
    if thats the only way then thats the only way. Sometimes it just has to come off. i take it is a solid wall and not a stud seeing as you mention chased
    Oct 2009
    758
    youre bang on mjt, just hate taking stuff away
    Apr 2009
    2,686
    If it only leaks when used it has to be the waste or seal doesn't it? Unless operating the dial lets water up to a concealed point that it can't get to when off.
    *brilliant signature*
    dontknowitall's Avatar
    Apr 2008
    South Shropshire
    6,040
    Before breaking wall if you turn on shower and direct water into a bucket and no leak then it's not the supply pipes either (as you've already dismissed the waste). So next port of call would be the siliconing. If it's siliconed inside the shower this might be the cause of the problem.
    steveb's Avatar
    Nov 2007
    hythe hampshire
    8,983
    is it siliconed in the corner of the tiles or grouted?
  1. Shower pump question
    By enzyme in forum Plumbing Forum
    Last Post: 17-05-2010, 06:35 AM
  2. Shower Tray Question
    By Leoki in forum Bathrooms, Showers and Wetrooms
    Last Post: 05-04-2010, 10:45 PM
  3. mixer shower question
    By kowalski181 in forum Plumbing Forum
    Last Post: 10-01-2010, 04:30 PM
  4. Question over a new shower and pump
    By steviec54 in forum Bathrooms, Showers and Wetrooms
    Last Post: 28-10-2009, 10:11 PM
how to dismantle a sirrus shower tap.
dripping sirrus ts1700 shower valve
sirrus ts1700 issues
sirrus ts1700 wont turn off
sirrus signature dripping
ukplumbersforums.co.uk enclosed shower
