Plumbing & Plumbers Forum - problem flushing ideal standard dual flush (full flush)
Discuss problem flushing ideal standard dual flush (full flush) in the Plumbing Forum at Plumbers Forums; Hello all, I've recently encountered a problem with a customers dual flush system. Its ideal standard, has a chrome flush plate with two buttons, large (full flush) and slightly smaller ...-
10-02-2011 #1New to Plumbing Forum
- Feb 2011
- 5
- Thanked 1 Time in 1 Post
Hello all, I've recently encountered a problem with a customers dual flush system. Its ideal standard, has a chrome flush plate with two buttons, large (full flush) and slightly smaller (half flush) The customer has two toilets within the property and both full flush systems are not operating correctly. I've removed the faceplate, two tubes are seen to connect to separate locking nuts on the pneumatic dual flush valve (SV05767). Ive removed the bellows washers but to the eye all looks fine with them. When i manually press the button beneath the bellows the flush works fine but when I reattach the bellows washer and press the full flush button on the face plate, it only partially opens, resulting in a weak, slow flush. Could the washers/bellows need replacing? the tubes look ok too, so Not sure what the problem is. Its like the air seal is lost. Can anyone suggest a possible or common problem with these?
Any help/advice is appreciated, thanks in advance!
10-02-2011 #2UK Plumbersforums Trusted Advisor.
- east london
- 6,666
- 9
Re: problem flushing ideal standard dual flush (full flush)
your not folding the tube as you replace the lid ?
The Following User Says Thank You to stevetheplumber For This Useful Post:
Aquaplumb (10-02-2011)
10-02-2011 #3New to Plumbing Forum
- Feb 2011
- 5
was carefull not to bend the tubes, so not that
10-02-2011 #4New to Plumbing Forum
- Feb 2011
- 5
oh ok, didnt see that, will check that one out thanks!
11-02-2011 #5Plumbing Forum Contributor
- Jan 2011
- Fleckney Leicestershire
- 31
- 4
- Thanked 3 Times in 3 Posts
Hey there not expensive just replace them
Imperial Dual Flush Siphon
By GQuigley67 in forum Fittings & PipesReplies: 6Last Post: 09-03-2013, 02:45 PM -
Toilet dual flush problem!
By johntmanic in forum Sanitary WareReplies: 9Last Post: 10-11-2011, 03:02 PM -
Problem filling tank on a dual flush toilet
By mrbud1972 in forum Plumbing ForumReplies: 10Last Post: 19-10-2010, 03:49 PM -
Roca (dual flush) cistern problem.
By Alpz in forum Sanitary WareReplies: 7Last Post: 04-01-2010, 08:47 PM -
Dual Flush
By claire21 in forum Sanitary WareReplies: 1Last Post: 12-10-2009, 10:01 PM
i'm too pretty to work
8 Minutes Ago in General Off-Topic Chat
