Results 1 to 12 of 19
Plumbing & Plumbers Forum - Alpha cd35c intermittant hot water (pulsing)
Discuss Alpha cd35c intermittant hot water (pulsing) at UK Plumbers Forums; HI Im having problems with the above boiler ! ch heating is fine but the hot water is hot cold hot cold etc whenever the dhw tap is on, i ...
    Jan 2011
    13
    Default Alpha cd35c intermittant hot water (pulsing)
    HI
    i was told it was a simple fix involving the diverter valve diaphram BUT i looked in there and looking at it its not the conventional valve we all know are these known for failing? . Is there anything else it could be ie flow switch etc
    Im also looking at a scale reducer (pre boiler) are the aqua-dial scale inhibitors any good??
    Many thanks for looking
    Jan 2011
    Charing
    1,053
    Default Re: Alpha cd35c intermittant hot water (pulsing)
    Either a blocked hw heat exchanger and temp sensor, as you have found out - they have no diaphragm and wont be divertor or motor either for this fault!
    My money is on the DHW heat exchanger.
    Is the boiler is under manufactures guarantee?
    Need an Alpha boiler repair or a service? If you're in Kent then give Alpha man a call to arrange a visit. Telephone 01233 712994, Steve, of Greenside Heating Services, GSR number 296.
    Sorry, no free technical advise given to the public either over the Internet or telephone.
    I will only visit if you're in KENT
    (I'm not Alpha nor work for them, just an Independant engineer.)
    Steve
  3. The Following User Says Thank You to Alpha man For This Useful Post:
    Jan 2011
    13
    My money is on the DHW heat exchanger. ooooooooooo crap
    Is the boiler is under manufactures guarantee? i think so
    many thanks
    Jan 2011
    Charing
    1,053
    Phone Alpha and find out if your still under guarantee!! may not cost you a penny??
    Steve
    Jan 2011
    13
    is there anyway of descaling it with the heat exchanger in situ ??
    also do you know if the aqua-dial scale inhibiter filters are worth the money as i live in a hard water area ?
    Jan 2011
    Charing
    1,053
    Its best to remove the H E and bench de-scale it! Manufactures dont normally recommend de scaler units.
    Where abouts do you live?
    Steve
    Jan 2011
    13
    somerset
    Jan 2011
    Charing
    1,053
    Too far for me, Alpha will be your best bet sadly!
    Steve
    Jan 2011
    13
    do you know if aquadial filters are any good??
    Jan 2011
    Charing
    1,053
    They never used to be! Google it?
    Steve
    Jan 2011
    13
    Quote Originally Posted by Alpha man View Post
    I have to no avail ! what pre boiler filtration do alpha recommend ?sorry to go on !
  13. #12
    Jan 2011
    Charing
    1,053
    They dont for mains water, if its heating water then its a Fernox TF1 on the return pipe to the boiler.
    Steve
  1. Pulsing Hot Water
    By TheBird in forum Central Heating Forum
    Last Post: 09-04-2013, 08:39 PM
  2. Alpha Hot Water problem
    By manxtapper in forum Gas Safe Register Forum - Public Forum
    Last Post: 30-01-2013, 10:23 PM
  3. Alpha CD35c NO HOT WATER
    By Kev the gas in forum Gas Safe Register Forum - Public Forum
    Last Post: 18-04-2012, 08:49 PM
  4. Alpha CD35C
    By Mikey456 in forum For Sale & Wanted
    Last Post: 23-06-2011, 07:16 PM
  5. Intermittant hot water!!
    By longboy68 in forum Central Heating Forum
    Last Post: 30-01-2011, 07:39 PM
  6. Intermittant Hot Water. Help!!!!
    By tenchking in forum Central Heating Forum
    Last Post: 30-09-2010, 01:05 PM
  7. alpha 240X no hot water
    By derrybongo in forum Central Heating Forum
    Last Post: 09-03-2010, 11:43 PM
  8. Hi
    By Matty A in forum New Member Introductions
    Last Post: 16-08-2007, 02:29 AM
alpha cd35c problems
alpha boiler cd35c faults
alpha boiler problems cd35calpha cd35c combi boiler water filterheat exchanger for alpha boiler cd35c
