Results 1 to 12 of 803
Plumbing & Plumbers Forum - Hints, tips & secrets of plumbing - No Banter please!
Discuss Hints, tips & secrets of plumbing - No Banter please! in the Plumbing Forum at Plumbers Forums; put your hints and tips that may help others in this thread guys, http://brittgas.weebly.com/ http://brittgas.weebly.com/...-
14-01-2011 #1SUPER MODERATOR
- Jan 2009
- sherrif county
- 9,257
- 242
- Thanked 541 Times in 504 Posts
http://brittgas.weebly.com/ http://brittgas.weebly.com/Last edited by REDSAW; 15-06-2011 at 12:08 AM.
¿ʞɹoʍ sɐƃ
14-01-2011 #2Plumbing Forum Contributor
- Nov 2010
- Belfast
- 88
- 11
- Thanked 5 Times in 5 Posts
re: Hints, tips & secrets of plumbing - No Banter please!
dont put pushfit on chrome pipe.......ever
The Following User Says Thank You to Twinhawk For This Useful Post:
14-01-2011 #3SUPER MODERATOR
- Jan 2009
- sherrif county
- 9,257
- 242
when buying 15 & 22mm e/f couplers, get the ones with a dimple rather than a crimp in the middle (the bit that stops the pipe).
as you can file the dimple and use them as slip couplers like for repairing nail holes in pipes where access is limited.
¿ʞɹoʍ sɐƃ
The Following 7 Users Say Thank You to REDSAW For This Useful Post:
bostonlincs (14-07-2011),Dsgas (12-12-2012),Gazebo (14-01-2011),moony (16-01-2011),nicky (27-01-2011),Rizme (06-03-2012),rocketmanbkk (18-12-2011)
14-01-2011 #4
14-01-2011 #5New to Plumbing Forum
- Jan 2010
- 3
always always always carry a spare gas bottle on your van..........
14-01-2011 #6Plumbing Forum Contributor
- Nov 2010
- Belfast
- 88
- 11
When you forget your lighter always remeber to turn the gas down before you light your ciggarette of the blowtorch
14-01-2011 #7UK Plumbersforums Trusted Advisor.
- Apr 2008
- South Shropshire
- 6,082
- 514
- Thanked 679 Times in 613 Posts
Understand how the water works and know how to turn it off in an emergency before you tackle a job. You don't always have to turn the water off to do every job (e.g. change a ball valve) but if something goes wrong (and it does) you need to know how to control the situation.
When cutting through a pipe/changing washer, drain down by opening a lower tap. For example, if changing a bathroom tap washer, turn off water then open downstairs tap then open bathroom tap. If you hear a suction noise, then you know the water's drained.
When turrning back on, check for air in each tap you've opened so customer doesn't get wet after you've left. If the water is cloudy it means there is still a potential for an air lock so keep stopping and running the water until it's clear.
The Following 4 Users Say Thank You to dontknowitall For This Useful Post:
bostonlincs (14-07-2011),Pritch (15-08-2011),Ted808 (05-04-2012)
14-01-2011 #8New to Plumbing Forum
- Jan 2010
- 3
14-01-2011 #9Plumbers Arms member
- Dec 2010
- Devon
- 605
- 16
- Thanked 83 Times in 68 Posts
Always fill the kettle before you turn the water off
The Following 8 Users Say Thank You to Bartdude For This Useful Post:
bostonlincs (14-07-2011),gunnerman (29-03-2013),King Plumb (22-01-2011),mitchellplumber (10-11-2011),Plumb God (04-09-2011),princejamo (10-08-2011),Rizme (06-03-2012),vaughan (02-02-2011)
14-01-2011 #10Plumbing Forum Contributor
- Nov 2010
- Belfast
- 88
- 11
Be carefull when soldering near block. And dont use a grinder when you have heating oil on your knee pads :S
14-01-2011 #11Plumbing Forum Contributor
- Nov 2010
- Belfast
- 88
- 11
A helpful one now, to rid airlocks in hot or cold open both taps whilst holding your hand over fosset, or use a section of hose
15-01-2011 #12UK Plumbersforums Trusted Advisor.
- Apr 2010
- Scotland
- 9,565
- 281
- Thanked 1,206 Times in 1,073 Posts
A pound in the hand is worth 2 in the book.
The Following 6 Users Say Thank You to tamz For This Useful Post:
bostonlincs (14-07-2011),kirkgas (04-02-2011),mitchellplumber (10-11-2011),Plumb God (04-09-2011),SafeGasInstall (16-01-2011),zeroscrew (11-06-2012)
Hints &tips
By rob2048 in forum Gas Safe Register Forum - Public ForumReplies: 2Last Post: 09-01-2013, 08:34 PM -
Business start up HINTS or TIPS
By Titanium Trades in forum Plumbing ForumReplies: 18Last Post: 14-05-2012, 08:18 PM -
Plumbing Tips
By Dan in forum Plumbing ForumReplies: 0Last Post: 06-11-2007, 03:48 AM
783Likes
SIAMP Skipper 45 Flush Problem
9 Minutes Ago in Plumbing Forum
