Results 1 to 10 of 10
Plumbing & Plumbers Forum - Boxing in pipework
Boxing in pipework
Discuss Boxing in pipework in the Plumbing Forum at Plumbers Forums; Hi All (I am not a pro plumber, a DIYer) I have a need to remove some plasterwork that has been made to box in some pipes. I will be ...-
27-12-2010 #1New to Plumbing Forum
- Dec 2010
- 25
Boxing in pipework
Hi All
I will be replacing it - I was wondering what methods are used nowadays to box in pipework?
It will be 'half height' - i.e around 5ft high and need a lid.
(the current set up is a full heigh plasterboard thing)
Would you get a plasterer in to do it or could you DIY it with with wood?
27-12-2010 #2Plumbers Arms member
- Jun 2008
- Nottingham
- 1,064
- 20
- Thanked 107 Times in 98 Posts
Re: Boxing in pipework
You can DIY with wood no problem. Just consider ease of access should you ever need to gain access to the pipes for any reason.
27-12-2010 #3Steady Plumbing Forum Contributor
- Nov 2010
- Bexhill, East Sussex
- 112
- 5
- Thanked 16 Times in 16 Posts
Wood. Easy access.
27-12-2010 #4UK Plumbersforums Trusted Advisor.
- east london
- 6,666
- 9
personally i would do it in woodif its pipework your not going to need to get tobattens and 6mm ply pin nailed on and filled
again its a personal thing but full hieght boxings usually are less noticable than half hieght once room is decorated asuming its in a corner
27-12-2010 #5New to Plumbing Forum
- Dec 2010
- 25
thanks
so ply wood and battens are the way to go?
its currently full height but i want to make it half height as that area than then be used for extra things like putting a cabient on the wall.....
this leas me onto another question then...
the current toilet set up is that the waste pipe is on the floor, the toilet is then on top of the waste and the cistern is above - see this pic
http://img35.imageshack.us/img35/3650/26122010.jpg
the question is, when i rebuild by box, how hard will it be to put the cistern into the box and have the toilet flush up against the box
am i limited by the toilet I buy or are they most adjustable - if so what sort o toilet should i buy?
presumably it will be too much hassle to put the waste pipe somewhere else (i note most toilets now seem to have them in the back disappearing into the wall. i am mainly interested in getting the cistern behind the wall if i can. that will also mean no water pipe will have to be visible as the feed will also be inside the box.
thanks.
27-12-2010 #6Moderator
- Nov 2007
- hythe hampshire
- 8,983
- 447
- Thanked 747 Times in 727 Posts
yes you can hide the cistern in the wall. you need a concealed cistern with a back to wall pan. all pipework will be hidden in the wall. you just have to make sure that there is enough room in the new wall for the soil pipe so that the pan fits without any gaps to the wall.
27-12-2010 #7Steady Plumbing Forum Contributor
- Apr 2010
- 106
- 8
- Thanked 2 Times in 2 Posts
i prefer to use mdf for boxing in pipes expecialy if its being painted, as it has a nice smooth finish
27-12-2010 #8uɐɯ sɐƃ moderator
- Jan 2010
- maesteg,south wales
- 13,355
- 828
just remember mdf dust causes nasty s in the lungs wear a mask
GASMAN
27-12-2010 #9Steady Plumbing Forum Contributor
- Apr 2010
- 106
- 8
27-12-2010 #10uɐɯ sɐƃ moderator
- Jan 2010
- 13,355
- 828
no min ffp2 prefo ffp3
GASMAN
Help maceratorthreatens to flood my toilet on boxing day
By ambermaja in forum Plumbing ForumReplies: 8Last Post: 27-12-2010, 03:15 PM -
boxing in external central heating pipework
By suedeheadwales in forum Fittings & PipesReplies: 20Last Post: 25-11-2010, 09:08 AM -
Boxing a Geberit UP320 concealed cistern with Sigma 50 plate
By lyrical in forum Sanitary WareReplies: 6Last Post: 16-10-2010, 01:14 AM -
CH Pipework
By Leoki in forum Central Heating ForumReplies: 1Last Post: 14-10-2009, 09:13 PM -
Boxing in poor copper pipe work
By Unregistered in forum Plumbing ForumReplies: 3Last Post: 11-04-2008, 04:12 PM
Variable flow Water Pump for...
45 Minutes Ago in Plumbing Forum
