Plumbing & Plumbers Forum - burst cold water pipes
Discuss burst cold water pipes in the Plumbing Forum at Plumbers Forums; hi there my cold water pipes has burst in kitchen, i have turned stop tap completly off , which is located in cellar, and opened cold water outlets to drain ...-
23-12-2010 #1New to Plumbing Forum
- Dec 2010
hi there my cold water pipes has burst in kitchen, i have turned stop tap completly off , which is located in cellar, and opened cold water outlets to drain the system. . but the boiler still sounds like its filling up.? just like when you flush toilet, the water fills up again in back of toilet, the burst pipes are still dripping , how can i drain ALL the water out of system then i can start to repair the pipes? please someone help.... kind regards lee
23-12-2010 #2Steady Plumbing Forum Contributor
- Sep 2010
- 163
- 4
- Thanked 4 Times in 4 Posts
Re: burst cold water pipes
He boiler? Or the hot water cylinder? Or tank in loft?
The Following User Says Thank You to brasso1981 For This Useful Post:
leeslater (23-12-2010)
23-12-2010 #3New to Plumbing Forum
- Dec 2010
boiler in bedroom. dont have hot water cylinder or tank in loft. think its condensing boiler,
23-12-2010 #4Steady Plumbing Forum Contributor
- Sep 2010
- 163
- 4
Are you sure they have thawed out properly?
23-12-2010 #5UK Plumbersforums Trusted Advisor.
- Jan 2008
- North Yorkshire
- 4,150
Stop tap maybe not completely shut
CH Flow pipes burning hot - Return Pipes cold
By Jodi Thomson in forum Central Heating ForumReplies: 53Last Post: 03-03-2013, 01:06 AM -
Can water pipes burst in cold weather even if heating on low ?.
By moira1950 in forum Central Heating ForumReplies: 2Last Post: 17-01-2013, 09:50 PM -
Hot and Cold pipes on Radiator
By Steven Williams in forum Central Heating ForumReplies: 2Last Post: 14-12-2010, 09:16 PM -
Help! Plumbing after burst water pipe
By spat82 in forum Plumbing ForumReplies: 5Last Post: 15-02-2010, 07:13 PM -
Flushing air from cold water pipes
By panicol in forum Plumbing ForumReplies: 4Last Post: 31-12-2008, 04:10 PM
fridge magnets
