Results 1 to 13 of 13
Plumbing & Plumbers Forum - Is there a plumbers trick for working out what is in a pipe?
Discuss Is there a plumbers trick for working out what is in a pipe? in the Plumbing Forum at Plumbers Forums; Hi all! Done the course now trying to replace bathroom. However, have found a mystery 15mm copper pipe that goes from kitchen via bathroom and into loft. It has nothing ...
    17
    Question Is there a plumbers trick for working out what is in a pipe?
    Hi all!
    However, have found a mystery 15mm copper pipe that goes from kitchen via bathroom and into loft. It has nothing coming off it (no taps etc) and i cannot access the other end of it in the loft (which disappears into a 22mm pipe). It's about 10m and has boxing out around it (so would be nice to get rid of). I have a feeling it's from some old system..
    Is there a plumbers trick to work out what is in a pipe? (Could it be gas from an old kitchen, or is it mains, or is it from the previous indirect system?)
    Thanks,
    Ol
    Jun 2010
    190
    Default Re: Is there a plumbers trick for working out what is in a pipe?
    could be anything but sounds like a mains pipe or maybe gas.
    fuzzy
    absolutely no idea, it can be hard to correctly identify, if it was essential you could find an appropiate place to cut it, turn off water gas heating, drain down, cu in, slowly fill and see if anything comes out, is it worth it?
  4. The Following User Says Thank You to fuzzy For This Useful Post:
    olfrog (23-12-2010)
    18
    the 22mm pipe could be a sleeve and it could be mains to the tank? or an old tank that used to be there
    Oct 2008
    685
    The plumber's trick is experience and know how. If you trace a pipe to identify you can normally work it out. If you can't leave it as you find it and never take a clients word for it. I got a call about three months ago because a joiner cut a capped lead pipe away as the client said it was dead for sure. And of course it wasn't.
    Twickenham
    182
    You might be able to tell if its mains if you ran the ball valve in the tank it should be a lot colder, also any compression joints along the line?
    Jan 2008
    North Yorkshire
    4,150
    To elaborate on the previous post, if there are any compression joints you could crack one open slightly and see if anything comes out.
  9. The Following User Says Thank You to WHPES For This Useful Post:
    olfrog (23-12-2010)
  10. #8
    SUPER MODERATOR
    REDSAW's Avatar
    Jan 2009
    sherrif county
    9,108
    if you cut into the pipe and it is wet, it will be water.
    if it smells, it could be gas.
    but i may be wrong?
    ¿ʞɹoʍ sɐƃ
  11. #9
    cut into the pipe?,the pipe would be broken,that 's not a good way.
    A new member ,hello everyone,I would like to share a lot with you guys ,my job is sth likewood pellets,pellet stoveandshipbuilding plate,sth like that ,glad to be here.
  12. #10
    Mar 2010
    gloucester
    117
    you dont say where it starts in the kitchen. ?
  13. #11
    17
    Thanks guys!
    Well, i couldn't wait so yesterday before i got a reply i turned off everything and sliced the pipe. Turned water on, nothing coming, turned gas on, whoosh! So, it's gas.
    I cut back the pipe into the loft, then wire-woolled the end and covered everything in boss white. Stuck a compression stopend on and tested it 3 times with some washing up liquid to see if there were any bubbles. Touch wood all seems fine!
    The strange thing is the amount of gas pipe work in the loft - maybe originally it had gas fires everywhere as it has pipes going everywhere.
    Ol
  14. #12
    SUPER MODERATOR
    REDSAW's Avatar
    Jan 2009
    sherrif county
    9,108
    washing up liquid eh!.
    classic.
    ¿ʞɹoʍ sɐƃ
  15. #13
    Jan 2008
    North Yorkshire
    4,150
    If you aren't 100% sure if you have drained the right pipe (EXCEPT if there may be a gas pipe there), have a self tapping screw handy, drill a hole in the pipe before you go at it with the pipe slice, and if water pors out, drive a self tapper into the hole wrapped with PTFE tape as a temporary plug.
  1. Replies: 84
    Last Post: 17-04-2013, 09:40 PM
  2. Replies: 1
    Last Post: 06-01-2012, 05:56 PM
  3. Will plumbers mait seal a 32mm ABS pipe joint?
    By robbie71 in forum Fittings & Pipes
    Last Post: 05-11-2010, 11:16 PM
  4. the famous polish plumbers/pipe stranglers
    By gas man in forum Plumbing Forum
    Last Post: 02-10-2010, 12:56 PM
  5. newbie needs new trick
    By 1smokinace in forum Plumbing Forum
    Last Post: 20-06-2009, 06:30 AM
