Results 1 to 15 of 20
Plumbing & Plumbers Forum - Toilet bowl fails to empty
Discuss Toilet bowl fails to empty in the Plumbing Forum at Plumbers Forums; I have a downstairs toilet which has a 90 degree pan connector with boss, and until a few months ago also had the washing machine outlet connected through the boss. ...
    Default Toilet bowl fails to empty
    I have a downstairs toilet which has a 90 degree pan connector with boss, and until a few months ago also had the washing machine outlet connected through the boss. I rerouted the washing machine, and I think, but am not sure, that about that time I started having flushing problems. The toilet is near the outside wall, so the soil pipe goes 90 degrees right out of toilet, then the soil pipe exits through the wall, turns 90 degrees down and straight into the ground, so there is effectively no soil stack.
    The bowl fills to the top,and over a period of time empties, with various gurgling and bubbling noises. It empties until the level in the bowl is well below normal, virtually empty.
    My first thought is to fit an AAV (?) which would presumably have to be internal (frost). If I release the plug on the boss I hear a hissing of air, which I had assumed was higher pressure in the soil pipe. Is this in fact a vacuum that would be cured by having an AAV? If so should I fit the AAV inside, or out, or just drill a hole in the top of the soil pipe bend outside ?
    John
    Plumbing Forum Contributor
    North East Scotland
    67
    Default Re: Toilet bowl fails to empty
    Hi John
    Just in the process of fitting a new bathroom and using an AAV. Firstly, are you sure the problem is due to not having a vent, I wouldn't expect the level of water in the bowl to drop so low if the vent was to blame, sounds more like a blockage. I think this depends on how easy it would be to fit either option and how much space you have.
    Sounds a bit odd that a washing machine was attached to this point! Could crack a couple of jokes......
    Hi there
    Just experimented some more, and on flush when the bowl fills up air bubbles come back into the bowl at the bottom. This would suggest positive pressure in the pan connector space, and I believe AAV is to counteract a vacuum effect. Also I stuck a pressure washer in the boss today, and although wasn't very effective as the nozzle was too big to get inside, nevertheless toilet seems to be emptying slightly faster. I will get some rods and see if I can get them right down the soil pipe. It does have two tight bends before it sets off for the road so could be that.
    Thanks again
    SUPER MODERATOR
    REDSAW's Avatar
    Jan 2009
    sherrif county
    9,094
    do you use those 'hang on the sides' toilet freshners?
    ¿ʞɹoʍ sɐƃ
    dontknowitall's Avatar
    Apr 2008
    South Shropshire
    6,039
    I use loo roll ...
    No I don't... is that significant?
    SUPER MODERATOR
    REDSAW's Avatar
    Jan 2009
    sherrif county
    9,094
    well, the last 4 like you discribe that i have done have all been blockages in the pan caused by these. i even had to replace one toilet because it wouldnt budge untill i smashed the pan to bits to see what was causing it.
    ¿ʞɹoʍ sɐƃ
    well i stuck a hosepipe up and wiggled it around ok and if i take the plug out and flush it seems ok, but with the plug in the boss the pressure seems to build. will check pan again
    ecowarm's Avatar
    Mar 2010
    lincolnshire
    3,737
    sounds like you need a vent
    Sep 2010
    Winchester
    223
    and a new hosepipe now
    well that's what i thought, but others seem to think differently. Won't be happy if i fit a vent and it doesn't fix it. will try rodding then a vent
    Update. If I temporarily fit some pipe to the boss so the soil pipe is open to the air the flush works perfectly, and the water level remains correct afterwards. Although there is a rush of air OUT of the pipe when flushing, from what I have read the flush will not be working because of a negative pressure, so an AAV should fix it, and I can fit an external one. Unless it's a build-up of positive pressure....
  13. #13
    Dec 2009
    40
    Johnmadbag.
    For goodness sake forget about an AAV
    READ the rerplies
    LISTERN to what people are telling you,
    You have a partial BLOCKAGE in your pipes.
    AN AAV will NOT HELP YOU
    An AAV will only let air INTO the system so will not work in your case.
    CLEAR THE PIPES and system will work.
    use the money saved on an AAV to install some rodding access points.
    David
  14. #14
    Oct 2008
    685
    I'd say it's a blockage. By the description of the soile route it is a stub stack going straight into the drain so shouldn't need a vent in most circumstances. I think the washing machine is a co-incidence can't see that making such a difference.
  15. #15
    uɐɯ sɐƃ moderator
    gas man's Avatar
    maesteg,south wales
    13,325
    sounds like your right in the...............
    GASMAN
    IMPOR
  1. Toilet bowl connected to Uralite pipe
    By dubman in forum Sanitary Ware
    Last Post: 23-08-2010, 11:48 AM
  2. Empty Tank problem
    By mizpol in forum Plumbing Forum
    Last Post: 11-07-2010, 09:12 PM
  3. Replies: 10
    Last Post: 06-06-2010, 09:33 PM
  4. Toilet bowl and seat problem
    By jhatter in forum Sanitary Ware
    Last Post: 21-05-2009, 10:53 AM
  5. Slipping on toilet bowl with rubber sleeve
    By dubman in forum Plumbing Forum
    Last Post: 02-01-2009, 01:20 AM
can you fit wc pan straight into manhole
pan conector aav
toilet bubbling .co.uk
downstairs toilet aav
wc fills up even with AAV fitted
