Results 1 to 15 of 19
Plumbing & Plumbers Forum - Baxi 133 HE Plus problems - Leak!
Discuss Baxi 133 HE Plus problems - Leak! in the Plumbing Forum at Plumbers Forums; Hi, I have a Baxi 133 HE Plus, it is leaking from the rear of the combustion chamber, behind the fan. Dripping to the bottom plate and then dripping to ...
    Default Baxi 133 HE Plus problems - Leak!
    I have a Baxi 133 HE Plus, it is leaking from the rear of the combustion chamber, behind the fan. Dripping to the bottom plate and then dripping to the front of the panel, where all controls are (Advanced Control PCB). I've had to resort to having a permanent cloth on the bottom plate to absord the water before it drips on the control panel.
    The leak occurs when the heating is on AND the hot water is running. At times, it just leaks with the heating on. When heating is off, there is no leak. When hot water is running (without heating on) there is no leak.
    Can anyone please help, I had a plumber (CORGI reg) check this and he too was confused and could not provide me with any resolution. I had to pay the full hour rate, without any fix or ideas of what can be done. Expensive.
    First image illustrates the puddle of water, and second image the drip from above. Hope these images provide better understanding.
    Can anyone please help.
    Thanks.
  2. Last edited by Confused_Baxi; 07-12-2010 at 09:24 PM. Reason: Added Images
  3. #2
    Nov 2009
    26
    Default Re: Baxi 133 HE Plus problems - Leak!
    Get a good one who is Gas-safe registered & who actually knows about boilers and not into ripping you off
    Thanks for the response, this engineer was registered and was recommended. But he hadn't seen anything like this before, even phoned Baxi when he was looking at the boiler and he couldn't still fix it.
    Nov 2009
    26
    Ok mate, I would think this could be a few things are you having to top up pressure on your boiler, if so you might be looking at main hex or if not might be flue connections or seals, recouperator (I think this boiler has one if so its a possibility).
    Leak on a recouperator makes sense because when the boiler is running and condensing it would collect and leak. Good Luck !!
    Thanks for the reply, no need to top up the pressure. The pressure remains between 1 and 2, normal. Although I did try to decrease pressure, thinking it was too high, but did not allow me to. The pressure tap does not work now, and the pressure is normal.
    Nov 2009
    26
    So you have ruled out any pressure loss I think this is related to when the boiler is condensing get your guy to remove the fan and check the recouperator.
    Ok, will do, any ideas how much this will cost and how much time it should take? Seems like a big job and wouldnt want to get ripped off.
    Nov 2009
    26
    Its difficult to say ! might need a few hours at your local gas-safe registered hourly rate. Or it might be that the recouperator has to be replaced, then if so its going to cost more. Difficult for me to assume how much as I work for a company.
    Jun 2010
    Cumberland
    975
    Get the engineer to check the seal between the combustion chamber base and the combustion chamber, and check the condensate hole is clear. Allow at least an hour, by the time the burner and fan have been remved and then the base
    uɐɯ sɐƃ moderator
    gas man's Avatar
    maesteg,south wales
    13,325
    needs servicing, or is frozen sounds like the heat exchanger drain hole for the condensate is blocked,causing the waste water to back up and come out were its not designed this boiler does not have a recupirater as its a band a,that is only applicable to a band b
    GASMAN
    IMPOR
    Hi, I forgot that you could add images, attached a couple and it illustrates the same description as written, hope this helps to provide better understanding. you may be able to see the splashes from above, and the drip in the 2nd image.
  13. #12
    Aug 2010
    belfast
    166
    have your engineer check the sump seal and flue seal, is it possible water is getting down the air intake of the flue or condensate water is getting into the air intake.
  14. #13
    uɐɯ sɐƃ moderator
    gas man's Avatar
    maesteg,south wales
    13,325
    Quote Originally Posted by Confused_Baxi View Post
    that conden bottles full,no fly by wire by the look of it,blocked or frozen pipework ,is this a new problem come about with the change in whether ?
    GASMAN
    IMPOR
  15. #14
    Jun 2010
    Cumberland
    975
    Its also remarkably clean for a 133 !
  16. #15
    uɐɯ sɐƃ moderator
    gas man's Avatar
    maesteg,south wales
    13,325
    and the burners not blown up and killed it.............YET
    GASMAN
    IMPOR
  1. Baxi Bermuda gas leak help.
    By valks1 in forum Central Heating Forum
    Last Post: 03-12-2010, 11:00 PM
  2. baxi 105e problems
    By scarfeuk in forum Central Heating Forum
    Last Post: 21-09-2010, 06:32 PM
  3. DHW Problems Baxi 105E
    By mark999 in forum Plumbing Forum
    Last Post: 14-07-2010, 12:39 PM
  4. Baxi 105e - Fan problems
    By craign37 in forum Central Heating Forum
    Last Post: 04-05-2010, 10:35 PM
  5. Water leak on Baxi Solo 2
    By pezza37 in forum Central Heating Forum
    Last Post: 27-12-2009, 03:31 PM
baxi 133 he plus faults
baxi 133 he plus problems leak
baxi combi 133 he plus leak
baxi combi 133 he plus problemsbaxi solo 15 he leaking condensatebaxi combi 133 he plus leakingbaxi 133 he problems
