Results 1 to 9 of 9
Plumbing & Plumbers Forum - 3 rads not working - rest are fine
Discuss 3 rads not working - rest are fine in the Plumbing Forum at Plumbers Forums; Hi,T I've just installed new radiators throughout the house. Most are regular convector rads, however i bought 3 graded designer column rads - they were graded because of slight cosmetic ...-
30-11-2010 #1New to Plumbing Forum
- Nov 2010
- 4
Hi,T
I've just installed new radiators throughout the house. Most are regular convector rads, however i bought 3 graded designer column rads - they were graded because of slight cosmetic blemishes. All rads are working except these three. On 2 of them the pipes leading to the valve and TRV are hot and on the third the pipes are not. 1 of them is slightly warm in a couple of areas of the radiator (not the bottom). All rads have TRVs on them. I have a vaillant system boiler and a megaflow system. Some of the rads upstairs are not as hot as others, although all heat up.
Can anyone suggest what the problem is. I assume unless the 3 rads are leaking they cant just not work.
I would appreacite any help and advice
30-11-2010 #2uɐɯ sɐƃ moderator
- Jan 2010
- maesteg,south wales
- 13,314
- 827
- Thanked 1,264 Times in 1,207 Posts
Re: 3 rads not working - rest are fine
have you vented them on re filling?
GASMAN
30-11-2010 #3New to Plumbing Forum
- Nov 2010
- 4
Yes, althought the water comes out in little spurts, so not a constant flow of water
30-11-2010 #4New to Plumbing Forum
- Nov 2010
- 4
Also, the megaflo was a systemfit one, so came preinstalled with a pump.The guy I had to install it took the pump off as he said that the vaillant 837 system boiler its connected to already has a pump - is this right?
30-11-2010 #5uɐɯ sɐƃ moderator
- Jan 2010
- 13,314
- 827
try knocking the rest off to pressure the new ones into working
GASMAN
30-11-2010 #6New to Plumbing Forum
- Nov 2010
- 4
OK will try that. Thanks. Just wanted to confirm that unless the rads are leaking they cant just not work (so stop working like electrical items)? Sorry, might be a stupid question but someone said they just dont work so may need replacing - but I cant see if they dont leak how a radiator could just not work
A radiator cannot - 'stop working' as such, there is a fault which will cause the problem. Radiators are solid items without moving parts that can 'go wrong'!
You have definately got air trapped in them anyway!
02-12-2010 #8Steady Plumbing Forum Contributor
- Feb 2010
- COUNTY DURHAM
- 110
- Thanked 5 Times in 5 Posts
and vent with the boiler off
02-12-2010 #9Steady Plumbing Forum Contributor
- Apr 2010
- Lancashire
- 104
- 12
- Thanked 4 Times in 4 Posts
If no luck try balancing the system out.
2 rads not working
By marsaday in forum Central Heating ForumReplies: 10Last Post: 05-11-2010, 08:41 AM -
rads upstairs not working
By bedspoolplayer in forum Central Heating ForumReplies: 10Last Post: 07-08-2010, 08:06 PM -
My rads are not working properly
By hiretools in forum Plumbing ForumReplies: 6Last Post: 24-02-2010, 07:21 PM -
Rads not working
By hurst1978 in forum Plumbing ForumReplies: 5Last Post: 19-01-2010, 06:01 PM -
one room hot rest cold
By LennieT in forum Plumbing ForumReplies: 4Last Post: 17-11-2008, 10:15 PM
Plumbing Down Under
