Old 22-11-2008   #1 (permalink)
duncanbru
View duncanbru's Photo Album
Default steam from elson tank
there is an elson tank located in an airing cupboard, directly above a potterton kingfisher mf50rs boiler, the pump runs, all the rads heat up, the over heat stat and thermister have been checked yet whenever the boiler is left on for over an hour it srarts to produce steam from the elson tank, which fills the room! and sugestions on probable causes?
many thanks duncan
duncanbru is offline   Reply With Quote
Old 22-11-2008   #2 (permalink)
Mike Jackson
View Mike Jackson's Photo Album
Default Re: steam from elson tank
Possibly pumping over.
Mike
Mike Jackson is offline   Reply With Quote
Old 22-11-2008   #3 (permalink)
duncanbru
considered this, pump was set on 2, dropped pump speed to 1 but still the same problem. the pump does look as though it has been changed at some point, is it possible that to big a pump has been fitted? any recomendations for pump size on a gravity hw / pumped ch system with arround 1.2m of head?
Old 23-11-2008   #4 (permalink)
justlead1
View justlead1's Photo Album
Hi. Duncan, Check the pump when fitted was not reversed (put in wrong way round) and is on lowest setting. When running, is water flowing from heating vent pipe, and if you can check heating cold feed for water movement (stick you hand in cistern) If its the vent pumping over it may be easier to extend the height of vent pipe than try to find an alternative pump. (assuming a standard circulater has been fitted. Good Luck
justlead1 is offline   Reply With Quote
Hot water storage tank leak in attic - strange situation wirral77 Plumbing Forum 1 16-11-2008 01:27 PM
F&E tank positioning spencer Plumbing Forum 0 28-08-2008 06:01 PM
Header tank sjaisie Plumbing Forum 2 27-08-2008 05:39 PM
water tank overflows not ball cock or split coil in cylinder dannyabb Central Heating Forum 14 25-08-2008 10:11 AM
Fortic Tank - Building Control ? Mramps Plumbing Forum 2 30-07-2008 10:13 PM
