Results 1 to 2 of 2
Plumbing & Plumbers Forum - accumulator tank
accumulator tank
Discuss accumulator tank in the Plumbing Forum at Plumbers Forums; i am going to install a multi fuel stove to heat an accumulator tank. i also have a gas combi boiler. is it possible to run two completely seperate systems ...
    Default accumulator tank
    i am going to install a multi fuel stove to heat an accumulator tank. i also have a gas combi boiler. is it possible to run two completely seperate systems for dhw and central heating. i was thinking by having three way valves on the central heating circuit this would keep the two systems seperate and then i could still use the combi when i dont have the heat in the accumulator.
    mark
    Plumbers Arms member Centralheatking's Avatar
    West Lancashire
    751
    Default Re: accumulator tank
    Whats the purpose of the accumulator ? If its hot water then keep both systems separate
    and install a dual coil cylinder - one coil from stove and one from boiler.
    Beyond that you are entering the bermuda triangle zone with stoves etc. wrongly planned, poorly fitted and you have a domestic bomb - see other threads on this forum.
    centralheatking
  1. Accumulator
    By BLOD in forum Plumbing Forum
    Last Post: 19-08-2010, 10:43 PM
  2. Horizontal Accumulator will it work???
    By Ringbolt in forum Renewable Energy
    Last Post: 16-06-2010, 08:27 PM
  3. Accumulator or Upgrade Mains?
    By Yogsey in forum Plumbing Forum
    Last Post: 04-05-2010, 05:23 PM
  4. C/H header tank feed pipe pushing hot water into tank
    By RON in forum Central Heating Forum
    Last Post: 16-06-2008, 09:57 PM
  5. C/H header tank feed pipe pushing hot water into tank
    Last Post: 05-06-2008, 11:19 PM
accumulator tanks plumbing
plumbing accumulator tank
accumulator tank central heating
mains gas boiler with accumulator tankcentral heating accumulator tankhow to plumb an accumulator tankwhat is an accumulator tank in plumbing systems
