Plumbing & Plumbers Forum - Solid Fuel Central Heating boiler
Discuss Solid Fuel Central Heating boiler in the Plumbing Forum at Plumbers Forums; back boiler.jpg Central Heating.jpg Hi guys, first post on these forums. I have a multifuel stove which can be converted into a boiler via a bolt-in 3-4kw 1 input/1 output ...-
16-11-2010 #1New to Plumbing Forum
- Oct 2010
- North West
back boiler.jpgCentral Heating.jpgHi guys, first post on these forums. I have a multifuel stove which can be converted into a boiler via a bolt-in 3-4kw 1 input/1 output boiler (picture attached), this is available on Ebay. I am undecided which is the best way to plumb it in. I know 3kw is relatively small, but I was planning in plumbing it initially to heat water through an indirect tank, which may also double as a heatsink (which is behind a wall behind and just above the stove). Any excess hot water to pump via a thermostat to one or two upstairs radiators, I have done a basic diagram. Would this configuration work safely? If not can anybody suggest a better way or of any tweaks that may improve the circuit? The manufacturers of the clip in boiler strongly recommend that radiators be pumped rather than gravity fed, although it would be ok for the hot water tank to be gravity fed. There may be excess hot water as we mainly use the shower in our household rather than baths.
Thanks in advance for your time and advice.
16-11-2010 #2Top Plumbing Forum Contributor
- Jan 2009
- dublin
- 377
- Thanked 4 Times in 4 Posts
Re: Solid Fuel Central Heating boiler
not something to be messed with ..are u a plumber ....back boilers are dangerous..dont mean to be preaching !!!!! dont get why it cant be gravity and i kw in 1 kw out ..whats that about..
land of saints and scholars
16-11-2010 #3Plumbers Arms member
- Nov 2010
- Havering
- 377
- 66
- Thanked 34 Times in 33 Posts
what's the motorised valve for?
16-11-2010 #4Plumbers Arms member
- Jul 2010
- West Lancashire
- 751
- 133
- Thanked 71 Times in 66 Posts
If you are not experienced/qualified in this type of work LEAVE it ALONE.
There have been a number of accidents recently specifically with back boilers
- wrongly installed there are a household bomb. Get a hetas registered
plumber to visit. Even if your circuit dia is correct and I dont like the 28mm - 22mm
on the primary circuit. If your joints are not sound you are dealing with very hot water
at times.
Underlying all this is the return to wood/solid fuel and people trying to go green and
heat their homes using less gas/oil/electric. We all see gas bangs and co deaths do
not become a victim of what is a new domestic heating danger zone
centralheatking
16-11-2010 #5Top Plumbing Forum Contributor
- Jan 2009
- dublin
- 377
few thing wrong with that drawing u are going on ...where did u get that drawning ???
16-11-2010 #6New to Plumbing Forum
- Oct 2010
- North West
Thanks everybody for the replies, I am a spark, although I can do plumbing I am not a qualified plumber, therefore am no expert in this field at all. I think I may be out of my depth here. When I bought the woodburner I had it drilled and capped ready to fit the boiler for future use, because at the time when I bought it I could not get a straight answer on how it should be plumbed.
Buffy 27.....Thanks for replying, the drawing is one which was suggested to me that may work. I have asked plumbers and have had conflicting replies to my questions. When you were saying there are problems with the drawing what were they?
Centralheatking...Thanks for replying, I know fitting a boiler can be dangerous thats why I never had it fitted when the woodburner was installed, I wanted to be absolutely 100% sure. I think it looks like I will probably have to get a HETAS engineer for a quote
Shorticus...Thanks for replying..The motorised valve is I believe is a safety device which springs shut when the pump is working and open when it is not working such as a power failure, allowing some of the excess hot water to flow in the direction of the radiators.
16-11-2010 #7Plumbers Arms member
- Nov 2010
- Havering
- 377
- 66
it would seem unusual to me for a motorised valve to be used in such a way however I'm no expert with solid fuel appliances and it's many years since I've worked with them, I'd probably go with centralheatking's advice too and get a HETAS guy in, good luck and hope you get it sorted.
The Following User Says Thank You to shorticus For This Useful Post:
jayjayjay (16-11-2010)
Solid Fuel Two pipe Heating
By mally46 in forum Central Heating ForumReplies: 2Last Post: 18-10-2010, 03:51 PM -
Whole New Solid Fuel Heating - Thermosyphon Height & Thermal Store Size?
By Simon1 in forum Central Heating ForumReplies: 2Last Post: 02-06-2010, 10:28 PM -
Linking solid fuel stove to central heating
By Tank in forum Central Heating ForumReplies: 6Last Post: 14-05-2010, 11:03 AM -
disconect solid fuel back boiler
By spencer in forum Plumbing ForumReplies: 5Last Post: 06-11-2009, 05:09 PM
Link Exchange - Plumbing Site
6 Minutes Ago in Links, Forum Updates, News and Site Suggestions
