Results 1 to 4 of 4
Plumbing & Plumbers Forum - tap head replacemnet kit wont work!!
Discuss tap head replacemnet kit wont work!! in the Plumbing Forum at Plumbers Forums; hi guys, i hve a mixer tp tap that was dripping even when tightened to the full. i decided i would change the heads as it wasnt much more expensive ...
    Aug 2010
    173
    Default tap head replacemnet kit wont work!!
    hi guys,
    i hve a mixer tp tap that was dripping even when tightened to the full. i decided i would change the heads as it wasnt much more expensive than just replcing the washer.
    anyway, ive now hit a problem, the tap head replacements fit fine but when i close the tap up it seems to still go past the stop point. this then makes the bit inside the head (plunger type thing with rubber washer fixed to it) come loose and falls out of the channel which then stop me turning the tap. only way to fix this is to remove the tap head replcement kit and screw it back in manually.
    when looking at it, its almost like the plunger is being 'allowed' to drop too low and that results in it coming out of the channel and then getting stuck
    cn someone tell me why this is, ive even tried a different set of heads and they do the same!!! should i have bought different size or something as i thought all tap heads were kin of unoversal apart from the ceramic quarter turn ones
    any help much appreciated
    Apr 2009
    2,688
    Default Re: tap head replacemnet kit wont work!!
    not all tap heads fit all taps i'm afraid.
    revert to plan b - change the washers. if still dripping you could try a cheap re-seating tool - just take your time and be gentle with it.
  3. *brilliant signature*
    May 2009
    7,303
    If you get tap reviver kits or adapter tap kits ect,they come with a spacer seat,that extends the head /washer depth as required,allowing to be fitted to deeper body seats such as the one you have
    mikegas's Avatar
    Feb 2010
    1,198
  6. The Following User Says Thank You to mikegas For This Useful Post:
    Puddle (15-11-2010)
  1. Shower wont stop
    By skate in forum Bathrooms, Showers and Wetrooms
    Last Post: 28-09-2010, 10:59 AM
  2. boilers ,=head work
    By gas man in forum Central Heating Forum
    Last Post: 09-03-2010, 11:14 PM
  3. Boiler wont fire up
    By Benj in forum Plumbing Forum
    Last Post: 01-10-2009, 02:14 PM
  4. radiator wont bleed?
    By obseen16 in forum Plumbing Forum
    Last Post: 02-03-2009, 08:41 PM
  5. Dealing with customers who wont pay
    By Phil in forum Plumbing Forum
    Last Post: 28-04-2008, 11:22 PM
how to fit tap reviver kit
fitting tap reviver kit
how to fit a tap reviver kit
how to fit reviver taps
fit tap reviver kit
plastic tapreviver head wont lift offhow to fit tap revivers
