Results 1 to 4 of 4
Plumbing & Plumbers Forum - back boiler problem
back boiler problem
Discuss back boiler problem in the Plumbing Forum at Plumbers Forums; the backboiler is not heating rads or hot water, a new grundfos pump was fitted and still the same problem, the flow pipe that comes directly from the boiler is ...-
11-11-2010 #1New to Plumbing Forum
- Mar 2010
- 6
back boiler problem
the backboiler is not heating rads or hot water, a new grundfos pump was fitted and still the same problem, the flow pipe that comes directly from the boiler is only luke warm after fire being lit for 2-3 hours.... the system is full...all suggestions welcome thanks
11-11-2010 #2Plumbers Arms member
- Jun 2009
- 753
- Thanked 22 Times in 22 Posts
Re: back boiler problem
you need a gsr engineer to look at boiler,has it been serviced at any time,could be a few things wrong,blocked h/e,incorrect gas pressure
,boiler stat
11-11-2010 #3New to Plumbing Forum
- Mar 2010
- 6
thanks for the reply but its a coal fire that heats the water in the back boiler, no gas..
12-11-2010 #4UK Plumbersforums Trusted Advisor.
- Aug 2008
- 1,529
- Thanked 100 Times in 93 Posts
Hi. The answer is burn more fuel.
The more you do the luckier you get
www.justlead.co.uk
Back boiler problem
By rudeboytee in forum Central Heating ForumReplies: 15Last Post: 22-04-2011, 08:29 PM -
Two pumps on a Baxi Back Boiler unit. Pumping over problem. Radiators pinholing
By buryboy in forum Central Heating ForumReplies: 23Last Post: 21-10-2010, 10:38 PM -
Back boiler
By ferga in forum Plumbing ForumReplies: 3Last Post: 20-08-2010, 10:45 PM -
Removing back boiler
By rmbp in forum Plumbing ForumReplies: 11Last Post: 09-06-2010, 07:52 PM -
back boiler
By gareth537 in forum Plumbing ForumReplies: 0Last Post: 31-07-2008, 07:39 PM
4 Minutes Ago in Plumbing Tools
