Plumbing & Plumbers Forum - Every time I turn off a tap my toilet starts to overflow?
Discuss Every time I turn off a tap my toilet starts to overflow? in the Plumbing Forum at Plumbers Forums; Hi, can anyone help with this one? A couple of weeks ago I noticed my toilet was making a high pitched noise every now and again when I flushed it, ...
    Default Every time I turn off a tap my toilet starts to overflow?
    Hi, can anyone help with this one? A couple of weeks ago I noticed my toilet was making a high pitched noise every now and again when I flushed it, but if I flushed it again is stopped. Now, every time I turn a tap off in the house/use the shower/washing machine or dishwasher, my toilet either starts to make this high pitched noise or increasingly has started to overflow. I then have to flush the toilet to make it stop. This problem seems to have started round about the time I started to use my central heating again which hasn't been used all summer but this could just be coincidence. I have a combi-boiler. Anybody know why this has started to happen and if there is a way I can resolve it?
    Thanks.
    Plumbers Arms member johnmcginty's Avatar
    Jan 2008
    leeds
    718
    Default Re: Every time I turn off a tap my toilet starts to overflow?
    Change your inlet float valve , or the washer for it.
  3. The Following User Says Thank You to johnmcginty For This Useful Post:
    MISS S (11-11-2010)
    Plumbstar Tom's Avatar
    Jul 2009
    Staffordshire
    2,548
    wont be anything to do with your heating
    the washer or diapragm on the inlet/float valve is failing and the changing of pressure from a tap turning off for example is causing the issue
    Regards
    Tom
  5. The Following User Says Thank You to Plumbstar Tom For This Useful Post:
    MISS S (11-11-2010)
  1. Hot water starts running cold(-ish) after just a few minutes
    By jondaniels in forum Plumbing Forum
    Last Post: 02-11-2010, 10:01 AM
  2. header tank overflow pipe into cistern overflow?
    By traineedrip in forum Plumbing Forum
    Last Post: 09-08-2010, 07:24 AM
  3. Boiler starts then stops.
    By GMAN6 in forum Plumbing Forum
    Last Post: 16-05-2010, 10:07 PM
  4. Long time lurker, first time poster :)
    By TradePlumbing in forum New Member Introductions
    Last Post: 25-01-2010, 04:07 PM
  5. Prima F30 boiler, starts with hair dryer!!!!
    By waynedance in forum Central Heating Forum
    Last Post: 03-02-2009, 10:17 PM
toilet flushers when taps turn on
how far to turn tap on toilet
toilet overflows when running my tap on
toilet runs when faucet turned on
when i run the cold tap why does the toilet overflow
turning tap on toilet noise
wc cistern overflows when tap turned
