Plumbing & Plumbers Forum - Will new pipework airlock?
Discuss Will new pipework airlock? in the Plumbing Forum at Plumbers Forums; Hi I hope someone can help me out with new central heating pipework I have installed in a new extention - 5 radiators fed by 22mm from existing house stepped ...
    Plumbing Forum Contributor
    North East Scotland
    67
    Default Will new pipework airlock?
    Hi
    I hope someone can help me out with new central heating pipework I have installed in a new extention - 5 radiators fed by 22mm from existing house stepped down to 15mm for each rad (or two). However, the existing house concrete floor is not level meaning the pipes slope upward to the point where they join the new build, where they then fall slightly to the drain points and rads. The concrete floor has 2" battons then flooring so there is not enough room to offset the floor uneveness (is that a word?!). Is this likely to cause an airlock, it is a standard gravity fed system?
    Thanks for any advice.
    uɐɯ sɐƃ moderator
    gas man's Avatar
    maesteg,south wales
    13,350
    Default Re: Will new pipework airlock?
    yes/maybe but do a search on here airlocks are every day occurrences
  3. GASMAN
    IMPOR
    Apr 2009
    2,686
    Basically if it does you can get rid of them with some simple bits of DIY equipment and some patience. Annoying on a job, not so bad in your own home on your own time.
    *brilliant signature*
    North East Scotland
    67
    Thanks for the replies - I did try a search, but I thought my airlock situation was unique! Good to know it will not be a major issue, the alternative is to get the sds out and chase a long channel out the concrete. I am thinking it will make sense to branch a radiator off at the high point to take the air to the rad - is this right?
    Thanks again
    fuzzy
    yes it can airlock, if u fit drain off lock shields you can back fill through a hose
  1. airlock
    By philtheflush in forum Plumbing Forum
    Last Post: 26-07-2010, 08:55 PM
  2. How do you get rid of an airlock in c/h
    By hiretools in forum Central Heating Forum
    Last Post: 25-02-2010, 01:57 PM
  3. Getting rid of an airlock
    By Mike Field in forum Bathrooms, Showers and Wetrooms
    Last Post: 13-06-2009, 08:21 AM
  4. How long does it take to get rid of an airlock
    By dewsbury in forum Central Heating Forum
    Last Post: 16-12-2008, 09:44 PM
plumbing sloping pipe airlock
high point central heating pipes airlock
bad piping air lock central heating added new radiators
do pipes on floor cause air lock
