problem with commercial boiler.
This is not so much a non functioning problem, more a need it better problem.
i work at a steam museum. we currently hold steam days 5 times a year where the boiler runs for 2 days at a time. the problem is that although some of the members know how to install and operate the boiler, the technical elements as to how to fix the problem we have are not there.
The boiler is a wee chieftain 4 with mobrey water level controls
The problem we are having is the boiler runs fine and brings pressure up fine and continues to hold pressure during use but when the water level gets low it dumps loads of cold water in and the boiler is then useless for about 15 mins and we have to shut down all the engines whilst the boiler recovers and preasure comes back up.
The solution that we have come up with so far it to try to pre heat the water a bit before it enters the boiler by pumping the water through the flue gasses out of the header tank and back in again. It was originaly planed to allow it to circulate on its own using the thermo cyphening but after some discusion we stuck a centeral heating pump in there to help it along somewhat.
in conclusion (and the real question)
It could all be solved in my oppinion by adjusting the boilers water intake level so its puts less water in more oftern. The blokes here recon it cant be done but i think it should just be a case of adjusting the micro switch that controles the fill up point.
Does anyone know if this can be done or have any advice as to how to get around the problem?
