Old 30-10-2008   #1 (permalink)
vancouverbc
View vancouverbc's Photo Album
Default How to join egr pipe that has been cut?
it is brass pipe with outside diameter of 2/3 inch made of brass material. i cut with hack saw. it is part of muffler system close to engine so very hot. are there any compression fittings that could withstand this level of heat? i dont really want to try to flare the ends as the material is hard and area inaccessible.
vancouverbc is offline   Reply With Quote
Old 31-10-2008   #2 (permalink)
marleyco
View marleyco's Photo Album
Default Re: How to join egr pipe that has been cut?
can you not join it using radiator hose and hose clips, its good on heat and is used on boat pipework and exhausts.
marleyco is offline   Reply With Quote
Old 03-11-2008   #3 (permalink)
vancouverbc
the egr is really hot and burns the rubber into charcoil.
Old 03-11-2008   #4 (permalink)
Spirit
View Spirit's Photo Album
Thumbs down Re: How to join egr pipe that has been cut?
What material are you trying to connect to it?
Spirit is offline   Reply With Quote
Old 03-11-2008   #5 (permalink)
vancouverbc
Quote:
its a brass pipe that i cut and want to reconnect . both sides are the same brass pipe. solder obviously doesnt work on brass .i cant even find a pipe with inside diameter of approx. .667 inches. i had a rubber hose that worked for about 6 months. i guess it burned and turned to charcoil and worked until it cracked apart into dust.
Old 04-11-2008   #6 (permalink)
marleyco
silver solder mate, prob be better using oxy acetylene. this will give a very long lasting joint. best to take pipe off eng, make jig if you need to make it fit perfect. engine manufacturers have a high temp hose that wont burn, what is the engine in or on?
failing that could you not start again but replacing pipe with metric new.
if the pipe is what i think it is, its possibly a brass alloy called yorcalbro.
other than if the pipe was metric then these are probably your only options. not trying too look too thick now, but i measure imperial in eigths, sixteenths, quarters etc, so size not really computing
Old 04-11-2008   #7 (permalink)
vancouverbc
ok. i guess i will buy one of those welders at the hardware store that have a small oxy and propane . i can heat the top and sides but not bottom. cant get it out of car. not sure if i can find the right sized pipe though. thanks for your help.
Old 04-11-2008   #8 (permalink)
Mike Jackson
View Mike Jackson's Photo Album
A possible bodge that I have used before to get me out of trouble is to split a small length of copper tube lengthwise, paste the inside with exhaust putty, wrap it round the joint and secure with a couple of jubilee clips.
Mike
Mike Jackson is offline   Reply With Quote
brass olive on hep2o pipe mcmoby69 Plumbing Forum 2 03-11-2008 12:06 AM
Boiler gas feed pipe pressure... JMA Plumbing Forum 11 03-11-2008 12:02 AM
Soil pipe leaking at night only? eddiesaint Plumbing Forum 6 14-08-2008 02:51 PM
old 2" steel pipe... steve Plumbing Forum 2 30-07-2008 09:13 AM
Size of waste vent pipe Drew1000 Plumbing Forum 3 20-07-2008 08:53 PM
