Plumbing & Plumbers Forum - Vokera unica HE combi- hot water activates when cold water tap is turned off
Discuss Vokera unica HE combi- hot water activates when cold water tap is turned off in the Plumbing Forum at Plumbers Forums; hi Guys i have hust had this new unit installed...and any time the cold tap or washing machine or dishwater takes cold water and stops ...the hot water side of ...-
02-10-2010 #1New to Plumbing Forum
- Oct 2010
hi Guys
i have hust had this new unit installed...and any time the cold tap or washing machine or dishwater takes cold water and stops ...the hot water side of the boiler starts up...it stays on for about 30 secs then switches off
im worried because with the dishwater and washer on at the same time the boiler is on and off many many times
is this a simple problem that can be fixed easy?
my old gravity feed boiler never had this problem
any help much appriechated
best wishes
john
03-10-2010 #2
Re: Vokera unica HE combi- hot water activates when cold water tap is turned off
Try getting a check valve fitted in the cold pipe to the boiler. Sounds like the pressure drop when the tap is turned on is triggering the boiler.
03-10-2010 #3uɐɯ sɐƃ moderator
- Jan 2010
- maesteg,south wales
- 13,355
- 828
you have a dead leg on the hot call your plumber back to vent it or cut it out
GASMAN
Shower pump activates when hot taps are turned off
By Brooksie1963 in forum Plumbing ForumReplies: 4Last Post: 02-10-2010, 06:48 PM -
Heating working, hot water not (until tap turned on)
By Berger in forum Plumbing ForumReplies: 20Last Post: 28-04-2010, 05:53 PM -
Thud noise when water is turned off - why?
By Flossie in forum Plumbing ForumReplies: 8Last Post: 26-03-2010, 08:27 PM -
hot water only when cold basin tap turned on
By carriesue in forum Plumbing ForumReplies: 4Last Post: 22-02-2010, 05:53 PM -
Water flowing into cold water tank from hot water cylinder
By rustyands in forum Plumbing ForumReplies: 3Last Post: 11-09-2009, 11:08 PM
Variable flow Water Pump for...
20 Minutes Ago in Plumbing Forum
