Results 1 to 13 of 13
Plumbing & Plumbers Forum - Unvented mixer tap
Unvented mixer tap
Discuss Unvented mixer tap in the Plumbing Forum at Plumbers Forums; Hi all i have a customer who wants me to fit a mixer shower on her bath,ive had a look and its a unvented sys. Am i allowed to do ...
    Feb 2009
    132
    Default Unvented mixer tap
    Am i allowed to do the job because i would have to turn the water off and drain down the hot water.
    Or is it a job for someone whos got unvented on the card
    cheers
  2. Last edited by bikerbas; 30-07-2010 at 05:40 PM.
  3. #2
    Aug 2008
    1,529
    Default Re: Unvented mixer tap
    Hi, Providing you turn of the energy source (immersion and or gas boiler) and water feeding the unit, i personally can not see a problem. Good Luck
    Plumbing Forum Contributor
    49
    Should be no problem you didn't fit the unvented system so a drain down and would be ok on your part.
    Feb 2009
    132
    Cheers for replys
    If i drain down will it need the pressure building up in the sys once the jobs done?
    49
    The unvented runs off mains so no
    Jun 2010
    698
    Will need to fit non-return valves to both hot & cold
    Feb 2009
    132
    Cheers for that very helpfull
    Gray0689's Avatar
    Jun 2010
    Northern Ireland
    4,669
    Default
    You don't need to fit non return valves turn off water drain at bath fit taps and turn water back on it's that simple
    uɐɯ sɐƃ moderator
    gas man's Avatar
    maesteg,south wales
    13,354
    Quote Originally Posted by aggis View Post
    they are built in to most thermostatic bar mixers
    GASMAN
    IMPOR
    Banned
    Jul 2009
    North Devon
    1,889
    if the cold water supply is taken off the balanced part of the unvented syste you dont need non return valves. You only have to turn off the cold feed to the unvented cylinder, open taps to reduce pressure and off you go, trickle when you cut pipework, cylinder doesnt need draining down if thats what was being discussed earlier, may have missed something tho
    Jun 2010
    698
    Quote Originally Posted by Gray0689 View Post
    If the H & C is unbalanced on an unvented system, best to fit them, as I have been recently dealing with many showers that are passing from cold to hot, therefore giving luke warm water. Agreed that balanced unvented dhw systems don't need non return valves & some mixer showers have them fitted [check MI ]
    But if not sure what system fit non return valves, for @£5 it'll save you going back at your own cost.
  13. #12
    Gray0689's Avatar
    Jun 2010
    Northern Ireland
    4,669
    Default
    The idea of un unvented cylinder is the hot and cold should be balanced if it is not it's fitted wrong
  14. #13
    Jun 2010
    698
    Agree, But do the fully trained only work in the plumbing & gas industry!
  1. mixer tap hell!
    By vanjanflo in forum Valves & Taps
    Last Post: 13-01-2011, 05:56 PM
  2. Mixer tap on a gravity fed hot water system
    By ksareen in forum Plumbing Forum
    Last Post: 02-07-2010, 10:18 AM
  3. Replies: 1
    Last Post: 21-05-2010, 10:18 PM
  4. Strange issue with a hot tap (mixer)
    By Smcart5 in forum Plumbing Forum
    Last Post: 02-03-2010, 09:54 PM
  5. Mixer shower tap problem
    By Twee in forum Plumbing Forum
    Last Post: 24-02-2010, 08:43 AM
plumbing a mixer shower on unvented
tap for unvented
unvented mixer shower only lukewarm
mixer tap unvented
shower mixer taps for unvented
unvented mixer tap
ukplumbersforums.co.uk cutting off water supply to tap unvented system
