Plumbing & Plumbers Forum - Britony Combi 80 SE. Help please.
Discuss Britony Combi 80 SE. Help please. in the Plumbing Forum at Plumbers Forums; Well! Basically I am having a battle of wills with my 8 yr old Britony combi 80 SE boiler. It suddenly started (well not quite suddenly, it just started and ...-
13-07-2010 #1New to Plumbing Forum
- Jul 2010
- Wakefield West Yorks.
- 3
It suddenly started (well not quite suddenly, it just started and got worse because I just put bigger bowls underneath,) leaking. It eventually seemed to be leaking from just about every point that you can think of. I am not a plumber, but I am an extremely competent D.I.Y.er. I have also worked in the motor trade, and am pretty much a hands on type of guy.
So far I have replaced most of the seals. the valve in the right hand hydraulic block, and the complete left hand hydraulic block. I really thought that I had cracked it tonight, but... It is leaking from the air separator valve on the top of the plastic pump housing. I know that I can buy a replacement for it but... I just can't fathom out how to get the damned thing out. I am loathe to get too heavy with it, in case I break the plastic housing, thus needing to buy a complete pump. I am unemployed, so basically I cannot afford to just go out and buy a new boiler and have it fitted, (much as I would like to.) I think that when we were sold this boiler, we were sold a "pup."
So if any of you guys could help me, I would be extremely grateful.
13-07-2010 #2Plumbers Arms member
- May 2009
- 7,303
- 218
Re: Britony Combi 80 SE. Help please.
The auto air vent/separator just unscrews from pump housing,once you get new part,you will see
13-07-2010 #3New to Plumbing Forum
- Jul 2010
- 3
Many thanks for your reply.
Maybe I was just being too careful, afraid to break the housing...
Edit. Now that I know it unscrews, I just attacked it again with waterpump pliers and it came out.
I was afraid to try too hard before, because I wasn't too sure if it unscrewed or was fastened in by some devious means...
Thanks very much for the info...Last edited by Mick Stupp; 13-07-2010 at 11:37 PM.
If it doesn't work after you have hit it with a hammer, then it must be an electrical fault.
Chaffateux britony combi se
By Plumbcrazy56 in forum Gas Safe Register Forum - Public ForumReplies: 9Last Post: 15-10-2010, 01:13 PM -
Britony combi se boiler
By BR111 in forum Central Heating ForumReplies: 22Last Post: 29-03-2010, 09:05 PM -
britony combi 80 boiler
By antony in forum Central Heating ForumReplies: 16Last Post: 09-03-2010, 09:35 PM -
Acceptable mains flow rate for combi boiler installation
By richard44 in forum Plumbing ForumReplies: 4Last Post: 02-03-2010, 07:58 PM -
Britony Combi SE 80 - Boiler problem
By tedson in forum Central Heating ForumReplies: 3Last Post: 26-11-2008, 06:31 PM
what is it ?
42 Minutes Ago in General Off-Topic Chat
