Old 14-09-2008   #1 (permalink)
plumermicky
View plumermicky's Photo Album
Default Soundness testing on copper/plastic pipe?
how dose it work? what kind equipment do you use? and what kinda rateing will it show, how would you find out by doing the test that theres no leaks in pipe work?
plumermicky is offline   Reply With Quote
Old 29-09-2008   #2 (permalink)
justlead1
View justlead1's Photo Album
Default Re: Soundness testing on copper/plastic pipe?
Hi. Find a point where you wish to test from, fit a valve on the pipe at this point, you need to fill the pipe work and purge air from pipes as filling via pipe caps/valves (what ever you use to cap off) once achieved. Disconnect the topping up supply and connect a proofing pump to the pipe work pump up to say 20 bar, the gauge on the pump will indicate this. If you get to this stage without problems, leave the pump for say 5 min to stabilize and then a further say 30 min, monitor the gauge for any drop in pressure. Visual inspection can also be carried out where possiable. If air is not removed prior to using the pump it will take for ever to reach pressure and is very dangerous as the air compresses can result in injury if fitting start flying about. (Water being incompressible will not have the explosive effect when the system is pressurised providing air is not present) Good Luck
justlead1 is offline   Reply With Quote
Boiler gas feed pipe pressure... JMA Plumbing Forum 11 03-11-2008 12:02 AM
flexible pipe for tiling kilty55 Plumbing Forum 2 16-08-2008 01:18 PM
Soil pipe leaking at night only? eddiesaint Plumbing Forum 6 14-08-2008 02:51 PM
old 2" steel pipe... steve Plumbing Forum 2 30-07-2008 09:13 AM
Size of waste vent pipe Drew1000 Plumbing Forum 3 20-07-2008 08:53 PM
