Results 1 to 8 of 8
Plumbing & Plumbers Forum - 250ltr megaflow..not enough DHW
Discuss 250ltr megaflow..not enough DHW in the Plumbing Forum at Plumbers Forums; Hi all, need some advice. Customer of mine has 5 adults living in a 5 bedroom house. Large shower enclosure and 2 ensuites all are fed from 250ltr megaflow but ...
    Nov 2009
    134
    Default 250ltr megaflow..not enough DHW
    Hi all, need some advice. Customer of mine has 5 adults living in a 5 bedroom house. Large shower enclosure and 2 ensuites all are fed from 250ltr megaflow but DHW runs out.Question is how can i give them more HW when its required, want to get it right first time, thanks.
    ecowarm's Avatar
    Mar 2010
    lincolnshire
    3,737
    Default Re: 250ltr megaflow..not enough DHW
    Quote Originally Posted by archiedale View Post
    Is the boiler firing but not able to keep up with the demand or is it on a timer and turned off when its most needed.
    This cylinder should keep up with the needs of 5 adults.
    Just had a thought its not one of them direct type just with immersion heaters is it?
    Nov 2009
    134
    Going to have a look in morning, thanks eco will let you know
    May 2010
    Manchester.
    15
    I would say the cylinder is not large enough. We have installed 2 250ltr santon cylinders for a 6 bed, 4 bathroom'd house before because of very large hot water demand. You will have to readjust the timer, as these cylinders recover in around 20 mins
    Blackcatgas's Avatar
    Oct 2009
    Nottingham
    1,672
    Quote Originally Posted by ecowarm View Post
    Agree with ecowarm.
    May 2009
    7,303
    Also check on wastage,have had this were hot water supply ok at night and weekend but mornings the problem time,this is because they get up, turn shower on ,moving dial to hot,so hot comes through faster,walk about,go to the loo,clean their teeth,clean the fluff out of their belly button,then turn shower down to correct temp,stand their for 15mins thinking how bad life is or were they are going in life,then wash,get out shower,examine them selves in mirror for 5 mins then turn shower off,or leave running for next person,then wonder why they only get a few showers
    At night or weekend,its dash ,dash quick shower and out,thus no problem
    Advise them to only turn shower on in morning,when they are ready to have shower and turn off afterwards,will find amount of showers will double
    imho
    Plumbstar Tom's Avatar
    Jul 2009
    Staffordshire
    2,547
    have you got flow limiters on the showers to restrict the amount of water used?
    Regards
    Tom
    Plumbing Forum Contributor
    Sep 2009
    66
    Quote Originally Posted by Plumbstar Tom View Post
    Agreed very important in fact i put flow limiters on all hot water outlet for unvented and combi boiler systems otherwise you end up small toilet handwash basins with 25 ltrs a min etc... complete waste. you have to strangle the water supply because councils do keep turning their flow and pressure down.
  1. Halstead Finest No DHW
    By Thesub in forum Central Heating Forum
    Last Post: 21-05-2010, 11:59 PM
  2. Two different temperatures fo UFH and Megaflow cylinder
    By evgeny in forum Central Heating Forum
    Last Post: 10-04-2010, 11:16 AM
  3. Megaflow losing air gap
    By dorsetchappie in forum Plumbing Forum
    Last Post: 08-03-2010, 05:33 PM
  4. Combi Boiler DHW only when CH on - help!
    By haggettd in forum Central Heating Forum
    Last Post: 23-11-2009, 09:35 PM
  5. Megaflow CL145
    By ukbeerman in forum Plumbing Forum
    Last Post: 11-08-2009, 10:46 AM
megaflow 250
250ltr megaflow
megaflow cl145 immersion question6 bedroom megaflow mega flow 250plumbing prices for 13 5 bed houseswhat size megaflo for 5 bedroom house
