connecting 40mm waste to a big hole in the ground????
hi all.
got a job where an outside toilet is to be taken out. simple enough, but in its place the customer wants an old belfast sink putting in. problem is that i cant take the waste out the wall or sides as there is no drains available, the only place it could go is down the hole thats left from where the toilet pan went, what is the best way to fit the waste into this hole? i have thought of putting the 40mm waste straight into the hole and just concrete up the big gap thats left. probably not the best way to go at it. is there any fittings i can get to push into the hole and reduce down? or does it look like ill be better off cementing it in place?????
any advice or products you can think of would be appreciated.
cheers guys,
P.s no snide remarks please. :P
