Chatrooms
T4TS plumbing scenarios -
Go Back   Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK > Plumbing Courses & Plumbing Training > Plumbing Courses
Notices
Old 30-01-2009   #1 (permalink)
LUCIALIA
Info
Default T4TS plumbing scenarios
Is anyone else having any problems with the scenarios, i just wanna chuck it out of the bloody window. If anyone has any walk throughs, it would be appreciated as i can fix the problem no worries but not complete it exactly as the program wants & it driving me nuts!
LUCIALIA is offline
Old 12-05-2009   #2 (permalink)
popyesthesailor
Info
Default Re: T4TS plumbing scenarios
hi mate i dont know how to do soundness test in senario 3
please help me
akh
popyesthesailor is offline
Old 12-05-2009   #3 (permalink)
stecunners
Info
hi mate, the scenarios are a pain,,,scenario 1 their are nineteen thing to check basically everything to do with the cold water system, count them as you go along isolators,taps,toilet etc,etc....
scenario 2 hot water check,the immersion heater has been left on and its too high,turn it down to 60 degrees again check everything to do with the hot water,
scenariol 3 not done that yet,got as far as a soundness test and failed so got bored with it.....good luck
stecunners is offline
Old 13-05-2009   #4 (permalink)
REDSAW34
REDSAW34's Avatar
Info
hi got this disk of a mate for fun.
check every thing that is wet plumbing, it will tell you if not relevant.
and dont forget to leave the house as you found it water / heat on doors shut etc.
REDSAW34 is offline
Old 17-05-2009   #5 (permalink)
Jamesyd82
Info
Good day one and all, I am also struggling with the soundness testing!! do you have to check each piece of pipework which is adjoined to the isolation/service valves?! I do know after many times of being told that you must turn the boiler OFF before you play with the gate valve. Will give it another attempt when kids are tucked up in bed!
Regards James
Jamesyd82 is offline
Old 27-06-2009   #6 (permalink)
andyb 1980
Info
I am also struggling with the soundness test in sanario 3, if anyone has any advice it will be very much appreciated
andyb 1980 is offline
Old 27-06-2009   #7 (permalink)
newbie1
Info
are you referring to a gas tightness test ?
newbie1 is offline
Old 29-06-2009   #8 (permalink)
andyb 1980
Info
no the soundness test for hot and cold water systems. (scenario 3 on the Trade 4 trade skills virtual reality cd). Ive read the guide in my book but its not the same in the VR house, you cant just go to your toolbox and grab a tool. the last problem i had to solve was two leaking taps but it wouldnt let me change the tap washers i had to replace the taps with new ones, shurely i should have had both options.
Old 11-07-2009   #9 (permalink)
wittek
Info
Did anybody finish the senario 2. I have problem with the hot water system check, rest is done, it is 18 points to inspect. Somebody can tell my whom from kitchen&cupboard has to by inspect. help please its getting me mad
wittek is offline
Old 11-07-2009   #10 (permalink)
Bob Croft
Info
I have not heard of these scenarios are they part of an on line plumbing course ? Where do you get the Cd's ?
Bob Croft is offline
5 Day Plumbing Course Dan Plumbing Courses 13 3 Weeks Ago 09:45 PM
2 Week Plumbing Courses Hawkofeagles Plumbing Courses 12 09-11-2009 03:21 PM
Plumbing Academy feedback - c&g level 3 Anakin Plumbing Courses Feedback 6 22-06-2009 12:55 PM
Advanced Plumbing Course Dan Plumbing Courses 0 30-12-2008 02:58 AM
Beginner in Plumbing Jason Plumbing Courses 12 30-07-2008 08:08 PM
