Page 3 of 4 FirstFirst 1234 LastLast
Results 25 to 36 of 46
Plumbing & Plumbers Forum - T4TS plumbing scenarios
Like Tree4Likes
Discuss T4TS plumbing scenarios at UK Plumbers Forums; what does that tell you about what your spending you hard earnt cash on??????????????? is it worth it???????...
  1. #25
    Mar 2010
    gloucester
    117
    Default Re: T4TS plumbing scenarios
  2. #26
    Jan 2011
    Finally completed scenario 3. soundness test. thanx 4 the help. Really have to search with the mouse and the graphics movement isn't good so the option wasn't appearing to connect pressure kit. thanx anyway
  3. #27
    Jan 2011
    Hi all im new to this site i've been trying to do scenario 3 managed to change taps do soundness check on the hot/cold and do the full system check but yet i still get you have not completed this scenario its becoming very frustrating out of intrest rockdude as you've completed it any ideas what im missing? I made sure the boiler was turned off before turning the gate valve off
  4. #28
    May 2010
    Leeds West Yorkshire
    111
    Why dont you contact your tutor team, thats what you are paying for.
  5. #29
    Jan 2011
    finally got scenario 3 completed!!! i have completion code and access code for the next scenario if any1 wants it :-)
  6. #30
    Jan 2011
    Quote Originally Posted by simondjuk View Post
    Im having the same problem now and its getting bloody annoying.
    I can do everything in this scenario apart from the Cold and Hot Water Soundness testing. What am I doing wrong
    Ive checked absolutely everything (twice!) and Ive even left it for 15 minutes in case but still No!!
    It would be nice to get more details from the results rather than 'you did not complete a soundness check on the hot water/cold water' At least give us a clue what we are missing
    Can anyone help before I start using the CD as a lethal weapon by throwing it at something?
    look under kitchen sink washer pipes not the valves red and blue pipes put cursor on pipes pressure test here
  7. The Following User Says Thank You to rockdude For This Useful Post:
  8. #31
    May 2011
    newcastle tyne & wear
    hi m8 senario 1 a col;d water system check i done every thing on it and still cant how 2 find out how 2 doing it it really got my head messed up
  9. #32
    Super Moderator
    steveb's Avatar
    Nov 2007
    hythe hampshire
    12,921
    not the best way to learn to do a job to be honest.
    The Turtle Moves
  10. #33
    fuzzy
    it should only be there to support learning not replace i. my fear is steve that people think this is enough
  11. #34
    Super Moderator
    steveb's Avatar
    Nov 2007
    hythe hampshire
    12,921
    it's just that the importance that people put on these scenarios. it's not like this in the real world at all. the stopcocks are not all in the same place for instance. even in the same row of houses the plumbing will most probably be different having been worked on over the years.
    The Turtle Moves
  12. #35
    fuzzy
    stop cocks only work for the first 12months after installation. then they are there just to confuse you or to be a divide between bleech and shoe polish in the sink cupboard
    steveb likes this.
  13. #36
    Jan 2011
    14
    Quote Originally Posted by Cool Duell View Post
    Hi This is what you need to do to complete S1.
    1) Go to Loft, remove lid from cold water tank, isolate water supply, switch to bathroom turn on hot water tap, switch back to loft replace float. Inspect 4 items in the loft. Replace lid(s) back on tanks.
    2) Switch to Bathroom turn off hot water tap. Inspect 6 items.
    3) Switch to Cloakroom Inspect 4 items.
    4) Switch to Kitchen Inspect 5 items here, Before inspecting all 5 items you need to open the draincock, freeze the pipe under the main stopcock get the main stopcock replaced, close the draincock, unfreeze the pipe and thats scenario 1 done.
    Remember in order to replace the main stopcock the issue in the loft needs to be resolved first.
    If you need further help with scenario 1 or any other scenario let me know.
  14. The Following User Says Thank You to Kams82 For This Useful Post:
  1. T4ts
    By trev69 in forum Plumbing Forum
    Last Post: 04-11-2014, 08:23 PM
  2. T4TS at ATL featherstone
    By andymc in forum Plumbing Courses
    Last Post: 28-12-2013, 03:52 PM
  3. t4ts plumbing
    By jon23 in forum New Member Introductions
    Last Post: 15-09-2012, 08:49 PM
  4. t4ts plumbing course
    By pennylane in forum Plumbing Courses Feedback
    Last Post: 01-09-2012, 07:50 AM
  5. T4TS......help
    By pepsi666 in forum Plumbing Forum
    Last Post: 07-06-2012, 04:21 PM
  6. T4ts?????????
    By gmar in forum Plumbing Courses
    Last Post: 22-09-2010, 08:27 AM
  7. T4TS Plumbing
    By Taffytim in forum Plumbing Forum
    Last Post: 20-08-2010, 09:51 PM
  8. T4ts
    By nelvis in forum New Member Introductions
    Last Post: 11-03-2010, 07:44 PM
  9. T4ts
    By stecunners in forum Plumbing Courses
    Last Post: 08-06-2009, 09:33 PM
  10. Radiator extension piece?
    By dundeenil in forum Central Heating Forum
    Last Post: 09-10-2008, 12:54 PM
full hot water system check
plumbing scenario 1
how to do a full hot water system check
virtual plumbing scenario 2
how to complete a hot water system check
