Page 11 of 14 FirstFirst ... 891011121314 LastLast
Results 121 to 132 of 166
Plumbing & Plumbers Forum - Train4Tradeskill pre attendence test.
Like Tree34Likes
Discuss Train4Tradeskill pre attendence test. at UK Plumbers Forums; Somebody post up a couple of questions from these impossible tests and your answers if you would be so kind....
  1. #121
    tamz's Avatar
    Scotland
    13,995
    Default Re: Train4Tradeskill pre attendence test.
  2. #122
    spanner's Avatar
    Aug 2010
    Archway, London UK
    1,112
    Completed in 2012 but I'll heck check out the questions I can find...
    tamz likes this.
    Safety Message
    CARBON MONOXIDE CAN BE FATAL THIS IS A RESULT OF POORLY MAINTAINED APPLIANCES DO NOT LEAVE IT TO CHANCE GET YOUR APPLIANCE SERVICED TODAY!!!
    If it aint broke don't try to fixit
  3. #123
    May 2013
    Enfield
    hi there
    did you receive any answers? I have the same problem with t4ts.
  4. #124
    spanner's Avatar
    Aug 2010
    Archway, London UK
    1,112
    No never even had the opportunity of being able to check out as yet pal. Can I ask what module you up to or is it just the pre attendance test???
    Safety Message
  5. #125
    Jun 2012
    80
    Hi Kris
    Is this in relation to the multi choice?
    Unfortunately the questions are randomized and if you fail you get a mostly new set the next attempt, some questions may be same but not all.
    It is very frustrating because even if you fail you don't which area was weak that you need to improve on. I did the test 3 times and then sat the written one. The written one bears no resemblence to the multi choice and took me months to complete (sigh.....)
    There was a positive post from "Jim Henessy" that seemd to say that he passed without issue so it must be possible (i cannot convey sarcasm when writing....)
  6. #126
    May 2013
    Enfield
    Quote Originally Posted by spanner View Post
    I finished lesson 22 and should go for practice but I stuck .
  7. #127
    spanner's Avatar
    Aug 2010
    Archway, London UK
    1,112
    Where did you get stuck???
    Safety Message
  8. #128
    May 2013
    Enfield
    Hi there
    I stuck on beginning, do not how to do risk assessment. Did you done this house refurbishment?
    If not so maybe you know someone who pass it?
  9. #129
    spanner's Avatar
    Aug 2010
    Archway, London UK
    1,112
    You have to do an assessment before you start any practical task. Prior to this is to is to count as many unsafe situations that maybe caused and to prevent them from happening and to ensure that people around you are aware of any action carried out and everyone is safe. Example if you're looking into a trench you have to be standing up behind barriers. Example if you are cleaning up debris which may contain dangerous or sharp objects you would have been told in doing so prior to your risk assessment and or a toolbox talk.. Hope that helps us
    Safety Message
  10. #130
    spanner's Avatar
    Aug 2010
    Archway, London UK
    1,112
    any more questions I'm happy to help you find out what you need to know about this and tasks. No problem
    Safety Message
  11. #131
    Surprise surprise, more people astonished by this T4TS H&S Assignment. My experience was 4 failed attempts on the online test and then about a month to complete the written paper doing it a couple of hours a night. Out of 12 other people on the course I talked to, none passed the online test so well done to the peeps that have passed it though I'd guess a little luck may have played a part in it - as an HSE officer with 18 yrs exp, said to me when he saw it.
    It did appear without warning which wasn't good and needed hours of online research, gnashing of teeth and reading of HSE doc's and papers. Straightforward enough for someone that is comfortable with doing research, study and transposing it all onto paper but I'd guess a real minefield for anyone that isn't comfortable/competent with doing all that online research, study and written work, which seems a bit biased. I ended up with 2 answer papers, each of them 15 pages. Wasn't easy tho and I consider myself to be reasonably well educated.
    My solution was - 95% of the answers are on the HSE website - lots of hours searching and 20 odd PDF docs later! Searched for each question in there, downloaded the relative docs and then copied the required answers from them and then reworded to avoid the plagiarism rules.
    I have some info that it may have been designed to slow people down as many are running through the TMA's too quickly for them to keep up with available practical assignment slots without it costing them.
    All this being said though, I now know a lot more about H&S, which isn't a bad thing I guess, and was happy enough with the actual course, TMA's and Practical.
  12. #132
    spanner's Avatar
    Aug 2010
    Archway, London UK
    1,112
    Well did
    Safety Message
  1. Looking for experience
  2. test Certs
    By phil c in forum Plumbing Forum
    Last Post: 18-03-2013, 06:55 PM
  3. Test
    By cardigan in forum I'm looking for a Plumber or Gas Engineer
    Last Post: 14-02-2013, 11:05 PM
  4. this is a tap test
    By REDSAW in forum Valves & Taps
    Last Post: 10-02-2013, 07:43 AM
  5. Test to see if ...
    By dontknowitall in forum General Off-Topic Chat
    Last Post: 05-02-2013, 10:50 PM
  6. short circuit test and resistance to earth test on combi
    By cobra in forum Central Heating Forum
    Last Post: 03-08-2011, 08:05 AM
pre-attendance test 1 - health & safety
no work prior to safetyenvironmental induction sign
atlpt pre attendance test
Train4tradeskills feedback
health and safety assignment detached house refurbishment
