Plumbing & Plumbers Forum - Does this pic show evidence of leak inside Combi boiler?
Like Tree3Likes
  • 3 Post By venton
Discuss Does this pic show evidence of leak inside Combi boiler? at UK Plumbers Forums; As per previous posts, I'm having a bit of a nightmare with pressure drop on Firebird Oil Combi condensing boiler. I've done all I can to prove no leak on ...
    Jan 2017
    10
    Default Does this pic show evidence of leak inside Combi boiler?
    I've done all I can to prove no leak on pipework (professional pressure tests, gas, thermal, visual).
    No leak from PRV or trap. Adding half bar a day into loop to keep pressure up.
    But water is going in, and not coming out. On previous thread, was suggested water could be vapourising inside boiler.
    So I called out Firebird to sort out under warranty.
    As they were dismantling, I took this photo. It appears to show tap water mineral deposit from evaporating water (boiler is 2 month old). This is on the bit of metal at front. I didn't get photo, but with this strip of metal removed, there was further evidence of dryed staining/ deposits.
    Is this evidence of leak, which wouldn't show up due to evaporation?
    They said they would go away to think about it.
    I am a layman so could be wrong here, so advice appreciated. Thanks.
    Attached Thumbnails Attached Thumbnails Does this pic show evidence of leak inside Combi boiler?-leak1.jpg
    SimonG's Avatar
    16,219
    Default Re: Does this pic show evidence of leak inside Combi boiler?
    You've had some crap with this boiler and shown a tremendous amount of patience. But now you need to get heavy with Firebird. It's not the system, you've had that proven. Firebird need to get it sorted, not only is all the fresh water affecting the boiler but also the rest of the system
    deg
    deg is offline
    Oct 2008
    31
    Hard to know from that pic. Is that not where the condensate water gathers?
    Jan 2017
    10
    Just to report back... had a new boiler fitted (same model) and all fine now, no more pressure drops. Thanks for advice, it took a lot of convincing to get them to change it.
    SimonG, Geyser and zzzjim like this.
    SimonG's Avatar
    16,219
    Thanks for coming back and letting us know.
  1. Re Leak from combi boiler.
    By maxi in forum Gas Safe Register Forum - Public Forum
    Last Post: 05-01-2016, 10:04 PM
  2. Leak from combi boiler
    Last Post: 05-01-2016, 08:56 PM
  3. Show us the inside if your van!!!
    By sav in forum General Off-Topic Chat
    Last Post: 13-03-2014, 08:04 PM
  4. Leak inside boiler (Grant Vortex 36)
    By Paul Brown in forum Oil and Solid Fuel Forum
    Last Post: 29-08-2013, 11:50 PM
  5. Replies: 12
    Last Post: 11-10-2012, 09:50 PM
