Results 1 to 12 of 23
Plumbing & Plumbers Forum - Riello RDB Pump Needle (Solenoid) Valve
Like Tree21Likes
Discuss Riello RDB Pump Needle (Solenoid) Valve at UK Plumbers Forums; Hi Can anyone tell me how much travel there should be on the "plunger" of the Valve, the one I currently have fitted seems to have virtually none, also should ...
    Jan 2017
    Default Riello RDB Pump Needle (Solenoid) Valve
    Hi
    Can anyone tell me how much travel there should be on the "plunger" of the Valve, the one I currently have fitted seems to have virtually none, also should the plunger and stem be able to be separated for cleaning?
    Mine can't..... just trying to establish if it is jammed and needs replacing, I can rotate the "plunger" with a needle through the port holes and that is about all
    Forum Thug
    croppie's Avatar
    23,894
    Default Re: Riello RDB Pump Needle (Solenoid) Valve
    How are you going to set the pump up after you've finished faffing about with it?
    Croppie
    (By the way, I'm commercial!)
    Somewhere in the South West
    114
    Hello Bedlam
    Can I ask what has brought you to want to start dismantling the coil stem of an oil pump?
    SimonG's Avatar
    16,220
    Eh up. They're all out tonight.
    johnf, rpm and Best like this.
    Last Plumber's Avatar
    Aug 2016
    Lancashire
    1,588
    You are, I would guess, inexperienced with these appliances.
    These burners/Boilers can be extremely dangerous.
    Please get a qualified oil technician/Heating Engineer to reassemble it/ repair and recommission it for you.
    Jan 2017
    Quote Originally Posted by johnf View Post
    Hello Bedlam
    I am trying to eliminate a "lock out", I am aware that I cannot set up Pressure, Emissions etc.
    although removal of the valve should not affect that - should it?
    I just wish to establish how much lateral movement there should be on the "plunger" is all, it rotates in the stem ok
    I am also not a numpty 30 years in power plants taught me that
    114
    And let them know if its an RDB or Mectron pump they need to bring with them once you have knackered the one you have!!!!
    Aug 2016
    Lancashire
    1,588
    Quote Originally Posted by bedlam View Post
    Very high pressure fuel pump and an overall sensitive bit of kit ( The Burner).
    It's really not worth trying to DIY.
    SimonG's Avatar
    16,220
    I'd like to eliminate people who think it's OK to play with things they should not.
    Looks like we both will be disappointed.
    Forum Thug
    croppie's Avatar
    23,894
    You've knackered the oil pump for a start. Which makes me question your last sentence.
    Croppie
    SimonG's Avatar
    16,220
    Although on the brighter side you may just be the statistic that rubber stamps a change in the regulations.
    Last Plumber and johnf like this.
    114
    What has brought you to think that it has anything to do with the coil stem? Have you eliminated electrodes, transformer, leads, control box, Coil, motor, photocell, pump performance/pressure using an oil gauge. Have you checked/ replaced the oil nozzle, checked filters on the oil line, checked that sufficient oil is reaching the burner. Have you checked combustion using an analyser?
    The above are all tests that should be done before starting to dismantle the coil stem. You are not on the right path to the diagnosis of this lockout and should get someone in who knows what they are doing for both safety and financial reasons.
    Best likes this.
  1. 3 Way Electromagnetic Solenoid Valve
    By enragedlime in forum Plumbing Forum
    Last Post: 11-03-2014, 03:24 PM
  2. Solenoid Valve - Direct Action
    By marvoni in forum Valves & Taps
    Last Post: 03-07-2012, 09:49 AM
  3. gas valve solenoid queston?
    By Gascat in forum Gas Safe Register Forum - Public Forum
    Last Post: 12-11-2010, 09:19 PM
