Plumbing & Plumbers Forum - Rayburn 400kpf
Rayburn 400kpf
Discuss Rayburn 400kpf at UK Plumbers Forums; Hi all, We recently moved house that has a rayburn 400kpf. There's a couple of issues I'd like to try and resolve. Firstly when turning the Rayburn on from cold, ...
    Jan 2017
    Default Rayburn 400kpf
    Hi all,
    We recently moved house that has a rayburn 400kpf. There's a couple of issues I'd like to try and resolve. Firstly when turning the Rayburn on from cold, it runs for 2-3mins then cuts off as tho upto temp. Move the temp dial down then up it starts again. But only for a minute before it cuts off again. We have to keep turning the dial up and down to get it up to temperature. I've changed the temp stat but the problem persists. Secondly. Should the powerflu outside continuously run while the mains are turned on. It never stops on 24/7. Is this correct?
    Hope someone can help!
    rpm
    rpm is offline
    Member rpm's Avatar
    Wherever I lay my hat
    7,823
    Default Re: Rayburn 400kpf
    Welcome to the forums Simon, there are experienced members who will be along to help, in the meantime do you have any service history of it?
    Jan 2017
    Hi, no unfortunately not. Was told it had been serviced in the summer. But nothing to prove. It works fine just that it cuts out all of the time. As stated. Not Lockout. Just as tho it has reached temp.
    rpm
    rpm is offline
    Member rpm's Avatar
    7,823
    Where about`s are you and the Rayburn Simon?
    Jan 2017
    We located in north Wales!
    Dec 2012
    947
    Boiler or cooker side that does it or both?
    Jan 2017
    It is just a cooker. Not central heating.
  1. Rayburn/Aga
    By Robert Tyrrell in forum Oil and Solid Fuel Forum
    Last Post: 09-09-2016, 08:18 PM
  2. rayburn
    By simon0703 in forum Oil and Solid Fuel Forum
    Last Post: 12-03-2013, 08:15 PM
  3. Rayburn
    By Kayt in forum Oil and Solid Fuel Forum
    Last Post: 11-04-2012, 07:33 PM
  4. Gas Rayburn
    By lpg lou in forum Central Heating Forum
    Last Post: 01-02-2010, 08:23 PM
