Plumbing & Plumbers Forum - Thermal Store
Thermal Store
Discuss Thermal Store at UK Plumbers Forums; Hi. I have a thermal store system, heated by Parkray log burner (LB) with a back boiler, and a Grant Oil fired (OFB) boiler. These have separate pumped circuits apart ...
    Dec 2016
    Tunbridge wells
    Default Thermal Store
    Hi.
    I have a thermal store system, heated by Parkray log burner (LB) with a back boiler, and a Grant Oil fired (OFB) boiler. These have separate pumped circuits apart from the thermal store. Using the Grant OFB as the heat source is no problem.
    The way its set up seems strange - when using the Parkray LB, the LB "hot stat" (stand alone) cuts in ok at hot temp set and starts the associated pump so water circulates thro LB and thermal store. Fine.
    When the coal fired boiler dies the pump continues to run circulating water thro the LB. boiler and thermal store until the water has cooled enough, and the LB stat switches off. This takes a long time and also lowers residual heat in the thermal store which is wasteful/inconvenient.
    If the programmer is on a "normal auto" programme, and the thermal store water is still hot/above LB stat temp setting (60deg.C), but below thermal store stat setting (90degC), the oil fired burner cuts in as it should, however the coal fired boiler pump then continues to run. I need a way of switching this pump off when no heat from the LB (could put manual off/on switch but....) suggestions on redesign welcomed
    Dec 2012
    964
    Default Re: Thermal Store
    I would suggest calling out a hetas engineer who specialises in these sorts of systems to look at the current setup to see what can be done.
    Dec 2016
    Tunbridge wells
    I thought I had one - the one who installed this. Anyone you care to recommend around Tunbridge Wells
  1. thermal store
    By damaan in forum Plumbing Forum
    Last Post: 02-11-2016, 08:13 PM
  2. which thermal store?
    By jimplumb in forum Renewable Energy
    Last Post: 12-11-2011, 05:03 AM
  3. Replies: 1
    Last Post: 14-09-2011, 02:03 PM
  4. Replies: 3
    Last Post: 07-09-2011, 09:07 PM
  5. Thermal store with UFH
    By ColdFeet in forum Central Heating Forum
    Last Post: 28-04-2010, 10:45 PM
