Results 1 to 6 of 6
Plumbing & Plumbers Forum - is this how my oil boiler works.....Grant Euroflame 90/120 Kitchen/utility boiler
Discuss is this how my oil boiler works.....Grant Euroflame 90/120 Kitchen/utility boiler at UK Plumbers Forums; Hi I have a Grant Euroflame 90/120 Kitchen/utility boiler and I think Iíve worked out how it works. The boiler is outside in a shed. Thereís a standard 3 wire ...
    Dec 2014
    11
    Default is this how my oil boiler works.....Grant Euroflame 90/120 Kitchen/utility boiler
    Hi
    Thereís a standard 3 wire mains power cord going into it (no other wires).
    4 pipes coming out, 2 heats the centre heating, 2 heats the hot water.
    Thereís 1 pump in the shed for the centre heating 1 pump in the house for the hot water.
    So as thereís only the power cable going into the oil boiler i think the boiler must only monitor the temperature of the water thatís actually in the boiler. So it must maintain the temp of say 1 litre of water so if the pump is turned on it heats all the water in the system.
    (At first I thought a thermostat inside the house would control the oil boiler but as no wires except the power cable goes into the boiler that canít be the caseÖ)
    So Iím now concluding that the room thermostat controls the centralheating pump and not the oil boiler and again the thermostat on the combo electric hot water cylinder must control the pump and not the oil boiler.
    Also if all of thatís correct then doesnít that mean if the oil boiler is constantly heating say that 1 litre of water for when the pump is turned on isnít that a waste.
    I would of hoped the thermostat would control the oil boiler directly and so it would only heat the required water..
    So how much of that is correctÖ.
    Dec 2012
    966
    Default Re: is this how my oil boiler works.....Grant Euroflame 90/120 Kitchen/utility boiler
    It should all be interlinked to give control over the boiler.
    If the boiler fires up on its own with no demand it's not wired correctly.
    Jun 2016
    That's how some older systems work. It's as you say...the boiler keeps itself hot then water is drawn off as needed.
    They were designed that way for simplicity when fuel was very cheap.
    You can improve the situation by modifying the controls so that you are only feeding power to the boiler when there is demand. However, this is not a DIY modification.
    Something you can do yourself is check that the insulation on the boiler and especially the pipework is in good order.
    SimonG's Avatar
    16,113
    As above. Old systems relied on boiler stat for control. Swap to S plan, get 2 or 3 estimates.
    Dec 2014
    11
    thanks..... when I get back from my hols ill look into that....
    Dec 2014
    11
    thanks ..... when I get back from my hols I'll look into that....
  1. Warmflow condensing utility boiler
    By tickdoc in forum Oil and Solid Fuel Forum
    Last Post: 21-03-2016, 08:30 PM
  2. Gas Safe engineer to service WB utility boiler Middlesbrough
    By WHPES in forum I'm looking for a Plumber or Gas Engineer
    Last Post: 23-09-2012, 11:18 PM
  3. Warmflow U70 Utility Room Boiler Problem
    By steve5345 in forum Plumbing Forum
    Last Post: 31-01-2012, 12:36 AM
  4. Grant euroflame 50/70 oil boiler failing to fire
    By andrewjeffs in forum Central Heating Forum
    Last Post: 16-11-2011, 05:17 PM
