Page 2 of 2 FirstFirst 12
Results 13 to 17 of 17
Plumbing & Plumbers Forum - Help.. Intermittent oil boiler lock out ( moved from Central heating Thread)
Like Tree2Likes
Discuss Help.. Intermittent oil boiler lock out ( moved from Central heating Thread) at UK Plumbers Forums; Remove tigerloop and change back to 1 piper. Had to do that to one week before last. Been fitted on a eaga job. Didn't need tigerloop and compression fittings everywhere....
  1. #13
    SimonG's Avatar
    16,195
    Default Re: Help.. Intermittent oil boiler lock out ( moved from Central heating Thread)
  2. #14
    Apr 2009
    91
    I considered that but MI says max pipe run for 0.5m head is 10mtrs @10mm and I have a 25metre run, Even if I upped it to 12mm that would only give me 20mtrs, Although should be fine when tank full..
  3. #15
    Apr 2009
    91
    Just back from the boiler. .. Checked all joints that I could access.
    Correct me if I have done this wrong...(Two Pipe system) I put a vacuum gauge on the pump and fired boiler, It read 0 vacuum pressure??.
    I then isolated the fuel at the tank and pressure dropped to -.05bar. I then switched the boiler off and the pressure held. I left it for about 30 min and only lost a fraction -.005bar.
    Opened the tank isolation valve and went back to 0.
    From this can I presume I have pressure tested all of the fuel line suction and return to tigerloop. ?? And they are OK..?
  4. #16
    Apr 2009
    91
    Quote Originally Posted by RayPlumb View Post
    Sorry Pressures are supposed to be -0.5bar at vacuum test. Cant read my own notes
  5. #17
    lame plumber's Avatar
    Nov 2012
    North Devon by the sea
    15,653
    hate to say it but a pressure test means you apply pressure to the line and look for a drop over time
    www.jcdheating.co.uk
  1. Challenging - Intermittent Central Heating Problem
    By pank0906 in forum Central Heating Forum
    Last Post: 23-02-2016, 06:18 PM
  2. Intermittent heat to central heating
    By ftrilby in forum Central Heating Forum
    Last Post: 20-11-2013, 07:32 PM
  3. Vokera Linea 735 Intermittent Central Heating
    By Alex Beach in forum Central Heating Forum
    Last Post: 04-01-2012, 11:35 AM
  4. Replies: 7
    Last Post: 30-12-2011, 03:57 PM
